irobertson's Avatar
G50 Disassembly
Hi guys,
I'm pulling the case apart on my G50 to replace the gaskets and have run into a snag, literally.
I have the case separated, but it seems to be fetching up on something near the shift rod and will only come apart about 1.5".
Any of you guys know what I'm missing here?
Old 09-04-2011, 08:29 AM
Did you remove the reverse light switch and pin?
07 GT3 Cup S 4.0, 00 986, 78 911 old school gt car
77 BMW R100S
99 Ducati 996S
04 BMW R1150R
DanielJacobsLLC.com
Old 09-04-2011, 09:27 AM
irobertson's Avatar
Switch, yes, but not the pin.
Old 09-04-2011, 09:31 AM
irobertson's Avatar
That did it Dan.
Can't believe that one wasn't obvious to me.
Late night brain fade. LOL
The mating surfaces of the case are oxidized, and the gaskets just lifted right off, no adhesion at all.
This explains why the thing was seeping oil.
Thanks again
Old 09-04-2011, 10:03 AM
This is something I might be doing when I re drop my '88's 3.2 to work on some leaks. Is there any advice on the gasket material or process to ensure no leaks?
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 08-13-2013, 11:28 AM
cycling has-been
bkreigsr's Avatar
Originally Posted by irobertson View Post
....The mating surfaces of the case are oxidized, and the gaskets just lifted right off, no adhesion at all.
This explains why the thing was seeping oil....
did the car sit idle for any long period of time? years?
Bill K
Old 08-13-2013, 11:45 AM
KTL KTL is offline
Schleprock
KTL's Avatar
The gaskets are just paper thin anyway and can deteriorate with time. A good gasket sealant like Loctite 574, Curil T, or Permatex Aviation Gasket Sealant (brown sticky goop) would do just fine as a replacement for the pesky, fragile paper gaskets.
Kevin L
'86 Carrera "Larry"
Old 08-13-2013, 12:49 PM
