Porsche fanatic
3.2L engine noise after track event
I have a semi-dedicated street legal track car, '74 911 with '85 3.2L. Stock engine except for bolt-on mods: K&N open filter, headers and megaphones on track and Steve Wong tune. I installed low-mileage 40k engine in 2003 and it has always run like a top. It has about 55k now.
I was running at Watkins Glen and noticed a louder than normal exhaust sound with a deeper tone, around Turn 9 and pulled into the pits immediately, i.e. only drove 2 turns at reduced speed. I parked the car and only drove it up on the trailer and into garage at home. There is a loud tick-tick-tick sound from the right bank and a minor vibration. Engine was not over-revved, no missed shifts. I did have an issue earlier in the day with stuck throttle due to bent linkage and turned off engine and coasted into pits but car ran fine after I fixed that. Looking for opinions where to start diagnosis: 1. Valve adjustment? What is symptom of broken rocker arm? 2. Broken exhaust stud? The megaphones were not supported and do vibrate.
'56 Speedster Guards Red '74 911 IROC- 3.2L, 22/28 tbars, 22 sways, Bilsteins, Big Reds, Seineshift, headers/M&K, slicks, 17" Fuchs, SW '95 993 -H&R coilovers, turbo sways, GT2 wing, Fabspeed '74 911 Targa, 87 944T, '75 911 Anniversary Edition-sold |
Hopefully somthing 'relatively' simple - with the unsupported mega phones maybe it broke a header where you cant see it and its just an exh leak? Kinda sounds like what you are describing.
erik.lombard@gmail.com 1994 Lotus Esprit S4 - interesting! 84 lime green back date (LWB 911R) SOLD ![]() RSR look hot rod, based on 75' SOLD ![]() 73 911t 3.0SC Hot rod Gulf Blue - Sold. |
Check to make sure that your header to exhaust port nuts are tight. Happened to me in a race once.
1970 914-6 GT Track Car 1974 IROC Track Car 1987 911 Targa 3.2 2008 BMW X5 |
Porsche fanatic
I noticed the muffler gaskets have deteriorated over time so could be a leak there too but the ticking and vibration are troubling. Obligatory picture of the patient when she's running good.
'56 Speedster Guards Red '74 911 IROC- 3.2L, 22/28 tbars, 22 sways, Bilsteins, Big Reds, Seineshift, headers/M&K, slicks, 17" Fuchs, SW '95 993 -H&R coilovers, turbo sways, GT2 wing, Fabspeed '74 911 Targa, 87 944T, '75 911 Anniversary Edition-sold Last edited by jager911; 08-13-2013 at 11:51 AM.. |
Before you panic, just do a valve adjustment. I would think if something bad happened, there would be a LOT of movement on your rocker arm.
I wonder if you could have done something to the exhaust?
Christopher Mahalick 1984 911 Targa, 1974 Lotus Europa TCS 2001 BMW 530i(5spd!), Ducati 900 SS/SP 2006 Kawasaki Ninja 250, 2015 Yamaha R3 1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750 |
Hmm yah, the vibration does not fit in with the diagnosis very well.
Porsche fanatic
Yep, will check that first. Haven't had time to look into anything yet.
He has a tick-tick-tick sound. Either an exhaust leak or a valve flung out of adjustment(best case).
