Are you running fuel pressure through those plastic filters? If so, how much?
Looks great Don. Keep us posted and I would imagine we'd like a video too. Best of luck.
Looking good John.
Going to be real fun. :-) Alfy should go this route with your old car too :-) |
Do you have enough traction?
http://forums.pelicanparts.com/uploa...1288935916.jpg well, I had to rebuild the plumbing rack. I had the solenoids out at the end and the lines wouldn't reach to the far side. it's a learning experience ;) engine running. no bottle yet. still need to fab the bottle base and run the n2o main supply line and a bit of wiring. http://forums.pelicanparts.com/uploa...1316835832.jpg a completely gratuitious, needless, pointless, silly vid. just cuz I love the sound. 911 3.0 engine with webers and nitrous - YouTube and when was the last time you saw one of these in a 1967 porsche 912? :rolleyes: http://forums.pelicanparts.com/uploa...1316836055.jpg |
too much is not enough!....just say yes.
Wow.
you've been busy this week. now I know why I didn't hear from you . When and where are the drags? Thunder mountain? Let me know ,maybe I'll shoot up there. |
Swb
How did you install a 915 in a swb car?
http://forums.pelicanparts.com/porsche-911-technical-forum/446271-help-please-putting-915-into-swb-axle-set-up.html http://forums.pelicanparts.com/porsche-911-technical-forum/446991-915-trans-into-swb-step-step-conversion.html |
got my bottle back today and stuck it in, went for a spin..................
:eek::D:eek::D:eek::D:eek::D:eek::D . |
Do you have a bottle heater blanket? You might consider it. Keeping the bottle temp up will get you consistant usage. Purge the lines before each use as well. |
it went pretty well. nothing too dramatic. tried in in fifth, then fourth, then third, then just a little tiny bit in second :rolleyes:. not neck snapping or anything, although in second and third it feels pretty dramatic. seat-of-the-pants feels like about 60 - 70 hp. don't think it's much more than that, which is fine by me. did notice a bit of pinging in fourth and fifth, not too surprised as I'm running 9.5 compression. I did dial the timing back a couple of degrees. I'll do a little more tuning and get some better gas. maybe I'll spring for some dyno time next month and get some hard numbers. this car is so quick normally I find I get a bit jaded.
overall pretty happy. not something I'll use on a daily basis but just what I need for that edge at the drag track. I'm building a 3.2 stroker this winter to go in this car, I might dial back the CR a little bit, make it easier to get good gas and run this set-up more comfortably. but mostly, let's be honest, it just looks wicked cool ;) http://forums.pelicanparts.com/uploa...1317182121.jpg note. between the tank certification place and the refill shop, someone dropped my bottle and bent the valve. the manager of the flaps ( Lordco, Canada only ) had them fill and send me a brand new tank. very cool. helps to have a good relationship with the local guys. . |
It doesn't just look wicked cool....it is wicked cool. Don... ...you are setting the 911 street rod bar way higher.
The real deal.........Massive X-Faktor. Al |
I see you are running MSD product, what about using an ignition retard that is activated when the nitrous switched on? You then wouldn't be stuck with a compromised setup off the bottle.
Start and Step Timing Control - 8987 |
So, how were the drags?
driver error, big time. I only had the car out a couple of times on the highway. not nearly enough time for tuning and set-up. and certainly not much preparation for drag racing. had some switching issues, when the nitrous came on I was pushed back in my seat, my foot lifted off the accelerator slightly, full throttle microswitch opened, car slowed, got back on the pedal. and repeat, and repeat. must have been entertaining to watch. gear shifting is really giving me some grief. you just CAN'T shift a 915 quickly, at least I can't. and racing jitters make my shifting erratic at best. I pulled another of my patented 1-2-1-3 shifts :rolleyes: I do have a four speed 901 box on the way, I find they seem to shift a little easier. we'll see. I want to go to a 4 box for this car anyway but can't for the life of me find a 915 four speed. the car has everything it needs to clean up, except a decent driver. we'll see what happens next year. as far as the nitrous, it works very well. I did have to wind back my timing 6 degrees or so. a fellow there suggested a very good idea. a separate one gallon fuel cell with race gas, or maybe straight toluene ( 114 octane ) to supply the fuel fogger. means I could leave my timing correct and still prevent the dt's on nitrous. anyway. it's a learning/experimentation process. here are somw vids. please excuse the shaky camera, my daughter wasn't too steady today. '67 912 drag racing october 2011 1 - YouTube '67 912 drag racing october 2011 2 - YouTube '67 912 drag racing october 2011 3 - YouTube '67 912 drag racing october 2011 4 - YouTube http://forums.pelicanparts.com/uploa...1317608571.jpg |
Retarded timing should give more power and efficiency due to less negative work being done on the piston as the mixture burns while the piston is on the compression stroke, if you can work out a sort of boost retard function.
MORE weight with an extra fuel tank, pump, regulator, etc. |
| All times are GMT -8. The time now is 04:07 AM. |
