Two tail lights, one brighter than the other? Your thoughts?
Just like the title says, 2005 997, my left running light/tail light is brighter than the right one. I did the obvious, check the bulb to make sure it's the correct one, then swapped the bulbs on each side. No dice, the left is still brighter.
Seems the left side must be getting more voltage. Any idea what's up or how to fix?
Mark Howard Baton Rouge, Louisiana 2023 Taycan GTS |
I'd look at a wiring diagram to see if they ground at different places. if so clean the ground for the dimmer one.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off. 2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver) |
muck-raker
Check and clean bulb socket/connector and work backwards, if necessary. If the socket cleaning doesn't work, make sure the positive connections and all related grounds are clean and well-connected. You'll probably need to pull the tail light in order to make sure all this stuff is good, clean and tight.
STONE '88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended. ![]() Deny Everything; Admit Nothing; and Always Make Counter-accusations
Disclaimer - I'll admit I know nothing about a 997 but isn't the left side a fog light and supposed to be brighter?
David 2015 Audi S3 1988 Carrera Coupe (gone and miss her) |
Gary R. Last edited by GaryR; 09-11-2011 at 02:58 PM.. |
Hi Dave,
I think Super Dave is correct, the difference being in the design of the lens. Lawrence |
There is a reason we know him as Super Dave! He is exactly correct. When the light switch is pulled on to the fog light setting, the left tail light is brighter. On the running setting, it is normal.
Even though I feel a little sheepish, I'll admit I don't know 997s well either just yet. Add this to your knowledge bank. Thx David.
Member 911 Anonymous
You may have broken PCB within the light housing. I have intermittent brake lights. I tried to clean and tweek the contacts but one day my brakes lights were going hay wire
![]() I disassembled my housing and discovered the PCB type backing had snapped and the hot lead was shorting out on the metal housing:
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
It's a friggin 997! He has the fog lights turned on! The car would have to be stored underwater to look like that!
Gary R. |
oops my bad
![]() Why the heck is he here???
Cause I'm an air cooled guy at heart and this is the only forum that actually responds to stupid questions like mine
Wer bremst verliert
Very funny.
I'll bet you $1 its a poor ground on the dim light.
2007 911 Turbo - Not a toy 1985 911 Cab - Wife's toy 1982 911 3.2 Indiash Rot Track Supercharged track toy 1978 911 3.0 Lichtbau toy "Gretchen" 1971 911 Targa S backroad toy |
winter
Please donate my $1 to Wayne and Pelican for the ongoing maintenance of these forums Last edited by Winter; 09-12-2011 at 07:16 PM.. |
Rear fog filament will be 21w just like a brake light. Ordinary tail light is only 5w, so yes, if he had the rear foglight turned on it would be a great deal brighter and very annoying for anyone driving behind him.
