-   -   Replacing burnt parts in tachometer (http://forums.pelicanparts.com/porsche-911-technical-forum/630609-replacing-burnt-parts-tachometer.html)
E Sully 09-21-2011 05:26 PM
When I changed out the odometer gear I photographed it last year.
village idiot 09-21-2011 07:50 PM
I saw Warren's thread while searching for answers, but it was a bit technical for me as they were discussing wave forms and other things that were way over my head.
porwolf, again, that was an excellent(educated obviously) guess.:D
Ed, thank again for the pic and info. Looks like I have a little electrical experiment to perform this weekend.
rick-l 09-21-2011 08:27 PM
Anyone read German?
the bigger pdf file
SAY115 datasheet and application note, data sheet, circuit, pdf, cross reference, pinout | Datasheet Archive
rick-l 09-21-2011 08:43 PM
That 47 uF 16 volt capacitor may be shorted out also.
rick-l 09-22-2011 11:42 AM
EDIT: Never mind..... Realizing it was a speedo and not a tachometer I can see the similarities to a UAF2115
ok what does endstufe mean? schalllung? stromquelle?
http://forums.pelicanparts.com/uploa...1316716878.jpg
porwolf 09-22-2011 12:31 PM
Here is a translation of rick-1's diagram. Also:
"Endstufe" = End Stage
"Schaltung" = Circuit Diagram
"Stromquelle" = Current Source
http://forums.pelicanparts.com/uploa...1316719770.jpg
porwolf 09-22-2011 12:37 PM
Hi "village idiot" (Obviously NOT!!!) thanks for the compliments. Keep enjoying the Aloha state like I did visiting wise for years:
porwolf 09-22-2011 01:17 PM
Forgot to include Hawaii picture. We all like pictures. Here it is: Maui 1995
http://forums.pelicanparts.com/uploa...1316722624.jpg
village idiot 09-23-2011 11:18 PM
nice!!
I'm going to try fixing this thing tomorrow. Will post results(if positive :D)
village idiot 09-29-2011 11:09 PM
well, I did manage to replace the resistor as well as replacing the broken odo gear. Unfortunately, while reassembling the unit I managed to break the needle shaft........ oh well, at least the guys at parts heaven had one on hand for a c-note and it's on the way. Thanks again to all those who helped:D
village idiot 09-30-2011 08:35 PM
Got the new(used) speedo and installed it. No joy, still not working. double and triple checked the wiring. The only thing I seem to be missing is the white w/red striped wire, which, if I'm not mistaken is only used for cars with cruise control or o2 mileage counter which I do not have.
I used an oscilloscope to check the trans-mounted sensor and it is producing a square-wave signal that changes in relationship to wheel speed. I'm stumped....................
HALP!
porwolf 09-30-2011 10:50 PM
Hi Tom,
you are really lucky with those speedometers!!! Looking around Pelican threads I found this one:
http://forums.pelicanparts.com/porsche-911-technical-forum/632126-video-how-test-speedometer.html
Could you do that test in the video?
Wolfgang.
village idiot 09-30-2011 11:17 PM
Originally Posted by porwolf (Post 6285205)
Hi Tom,
Wolfgang.
Wolfgang, I didn't need the test rig as I just swapped the speedo into my 88 Carrera and went for a drive. In that car it worked fine.
I am 95% sure I have the wiring correct so now I'm thinking the sender is at fault. I just can't bring myself to order a new one from our host for $150 on a hunch.
Tomorrow I'll pull the sender and check it out.
village idiot 10-01-2011 02:17 PM
HAHAHAHHAH!! took the sensor out and cleaned it as well as the "well" that it sits in. Also made sure the sensor was oriented in the well. Took it out for a spin, and to my surprise it worked!!
Not 100% perfect though, as it seems it reads a bit high. Oh well good enough to pass inspection.......Now on to the inop tach.................:D:D:D:D
Omegaman 05-19-2016 01:29 AM
Very useful info here, helped me fix my speedo. I had an open circuit 1n4148 diode and leaky 47uf 16v capacitor. Speedo swings full range at 12v 300HZ square wave.
Thanks!
oarable 05-19-2016 09:24 AM
Thanks for the pic E Sully. That is a great help! http://financeseeyou.com/red/images/7.gif
http://financeseeyou.com/red/images/8.gif http://financeseeyou.com/red/images/51.gif
