-   -   Replacing burnt parts in tachometer (http://forums.pelicanparts.com/porsche-911-technical-forum/630609-replacing-burnt-parts-tachometer.html)
village idiot 09-19-2011 08:41 PM
Had a small setback in trying to get all my gauges working on my RS impostor. While jimmying around with the wiper wiring I somehow managed to smoke something in my tach, rendering it useless. Previously, the tach was the only thing that worked. Pics below:
http://forums.pelicanparts.com/uploa...1316490005.jpg
and
http://forums.pelicanparts.com/uploa...1316490050.jpg
Anyone have an idea as to what needs to be replaced? HALP!!!
70SC 09-19-2011 09:14 PM
http://forums.pelicanparts.com/uploa...1316491877.jpg
Looks like a fried resister .Circled in yellow Make sure you replace it with one of the proper value. :cool: BTW NO cold solder joints :mad:
70SC 09-19-2011 09:15 PM
SmileWavyHi JB
village idiot 09-19-2011 09:41 PM
Originally Posted by Joe Bob (Post 6263706)
Unless you are a glutton punishment buy a used one....
BTW "ischmitz" gets his yayas off that kinda stuff....send him a pm.
Heh, after 5 years working on this thing I guess you could call me a glutton for punishment:D If I can find out the value for the resistor I'd give it a try. If it works it works, if not I'd only be out a small dollar amount. I will try pm'ing ischmitz to get his point of view. Thanks for the tipSmileWavy
porwolf 09-20-2011 01:09 AM
Looks like you accidentally touched the right end of the resistor in the first picture with ground while the left end was connected to 12V. In the second picture of the underside of the circuit board the burned resistor seemed to be connected to 12V, that's what I read there. The resistor looks like 1/4 Watt resistor that burned when 12V was accidentally connected across. It was probably loaded with maybe 5 Watts, that would burn it. Therefore the resistor value was likely around 30 Ohms. You could start trying with a 1 Kilo Ohm, see what happens, and work your way down from there.
village idiot 09-20-2011 01:18 AM
Thanks porwolf! I can't imagine they would cost much...... I wonder if the Radio Shack across the street has those.......
Thanks again!
dshepp806 09-20-2011 03:01 AM
I'd also replace those old electrolytic caps while in there..
Doyle
na2ub 09-20-2011 06:15 AM
There are other pics of tachs on this board. Since the marking bands are burnt off yours, check someone elses pictures to get the correct markings. The bands on the resistor designate what capacity it is. You should at least try to match the resistor perfectly. Replacing it is the easy part. Tachs vary slightly model to model, so make sure your board matches the reference board that you find as a picture.
HawgRyder 09-20-2011 09:53 AM
Any type of resistor and capacitor is available from Digi-Key.
The one you burnt looks like a film type resistor.
I also agree with the idea of replacing the capacitors...they are old..and prone to leakage...and cheap.
When you take out the old resistor...scrape the top of the board to get rid of as much carbon (black stuff) as you can (carbon is conductive) and wash the board with alcohol to clean it prior to doing the repair.
Good luck
Bob
porwolf 09-20-2011 01:31 PM
Bob Hutson is right. The resistors and capacitors are standard components that are always available at sites like DigiKey:
Electronic Components Distributor | DigiKey Corp. | US Home Page
or Mouser:
Mouser Electronics - Electronic Component Distributor
Radio Shack hardly caries basic electronic components components anymore.
village idiot 09-20-2011 02:24 PM
D'oh!! See user name. This was for my speedo, not my tach, although I'm having issues with that as well:mad:
village idiot 09-20-2011 02:29 PM
Thanks for th links porwolf.
This looks like what I would need, I think...
http://www.mouser.com/ProductDetail/Ohmite/OA330KE/?qs=sGAEpiMZZMsPqMdJzcrNwvtkBdlAWZkzZfyLH5WDWfI%3d
dad911 09-20-2011 02:46 PM
33 ohms is a wild guess, and could damage other components.....
I'm not going to analyze the circuit from pics, but it looks like a voltage divider, and wrong value will fry other parts.
dshepp806 09-20-2011 04:38 PM
The replacement value (resistance) has to be right,..period,..as would be the wattage rating..I'd go with the manufacturer's resistor "type" as well
Doyle
porwolf 09-21-2011 12:43 AM
I agree with dad911, the 30 ohms I suggested as a possibility is a wild guess. And yes, Doly is right in suggesting to try to find out what the right resistor value is. Are there any other pictures of the circuit board with a picture of an intact resistor posted somewhere else? Then we could read the Ohm value from the colored rings. For instance, the resistor next to the fried one on your board looks like a 5.1 Kilo Ohm value (green, brown, red).
E Sully 09-21-2011 04:36 AM
This pic might help you read the 4 bands on the burned resistor, and a link for a discussion on speedometers. You can get all the parts from Radio Shack
http://forums.pelicanparts.com/porsche-911-technical-forum/332604-smokey-speedo.html
http://forums.pelicanparts.com/uploa...1316604280.jpg
http://forums.pelicanparts.com/uploa...1316604382.jpg
dad911 09-21-2011 05:12 AM
good wild guess.... ;)
village idiot 09-21-2011 08:39 AM
Thanks for the pic E Sully. That is a great help!
E Sully 09-21-2011 11:08 AM
Your welcome. The rest of the info is thanks to Warren, early S man.
porwolf 09-21-2011 11:31 AM
Hey thanks Ed, That's phantastic. SO IT IS 33 OHMS, 1/2 WATT! Where did you get this picture so quick? I am amazed myself about the 30 Ohm, 1/2 Watt guess. So I was off by 3 Ohms!!
