I hate freight charges
village idiot's Avatar
Send a message via Yahoo to village idiot
Replacing burnt parts in tachometer
Had a small setback in trying to get all my gauges working on my RS impostor. While jimmying around with the wiper wiring I somehow managed to smoke something in my tach, rendering it useless. Previously, the tach was the only thing that worked. Pics below:
and
Anyone have an idea as to what needs to be replaced? HALP!!!
Tom
78 911SC SC to 73RS imposter SCWDP crew #50 and 51
1969 Camaro "The new project"
Old 09-19-2011, 08:41 PM
Canyon Runner
70SC's Avatar
Looks like a fried resister .Circled in yellow Make sure you replace it with one of the proper value. BTW NO cold solder joints
Old 09-19-2011, 09:14 PM
Canyon Runner
70SC's Avatar
Hi JB
Old 09-19-2011, 09:15 PM
Unless you are a glutton punishment buy a used one....
BTW "ischmitz" gets his yayas off that kinda stuff....send him a pm.
Heh, after 5 years working on this thing I guess you could call me a glutton for punishment If I can find out the value for the resistor I'd give it a try. If it works it works, if not I'd only be out a small dollar amount. I will try pm'ing ischmitz to get his point of view. Thanks for the tip
Tom
Old 09-19-2011, 09:41 PM
porwolf's Avatar
Looks like you accidentally touched the right end of the resistor in the first picture with ground while the left end was connected to 12V. In the second picture of the underside of the circuit board the burned resistor seemed to be connected to 12V, that's what I read there. The resistor looks like 1/4 Watt resistor that burned when 12V was accidentally connected across. It was probably loaded with maybe 5 Watts, that would burn it. Therefore the resistor value was likely around 30 Ohms. You could start trying with a 1 Kilo Ohm, see what happens, and work your way down from there.
79 SC Targa
72 T Targa Sold
68 T Coupe Sold
65 912 Coupe Sold
62 356B Coupe Sold
Old 09-20-2011, 01:09 AM
Thanks porwolf! I can't imagine they would cost much...... I wonder if the Radio Shack across the street has those.......
Thanks again!
Tom
Old 09-20-2011, 01:18 AM
dshepp806's Avatar
I'd also replace those old electrolytic caps while in there..
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 09-20-2011, 03:01 AM
na2ub's Avatar
There are other pics of tachs on this board. Since the marking bands are burnt off yours, check someone elses pictures to get the correct markings. The bands on the resistor designate what capacity it is. You should at least try to match the resistor perfectly. Replacing it is the easy part. Tachs vary slightly model to model, so make sure your board matches the reference board that you find as a picture.
Doug
79 SC Targa w/ ITBs, 2004 Cayenne Turbo
Old 09-20-2011, 06:15 AM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
Any type of resistor and capacitor is available from Digi-Key.
The one you burnt looks like a film type resistor.
I also agree with the idea of replacing the capacitors...they are old..and prone to leakage...and cheap.
When you take out the old resistor...scrape the top of the board to get rid of as much carbon (black stuff) as you can (carbon is conductive) and wash the board with alcohol to clean it prior to doing the repair.
Good luck
Bob
Bob Hutson
Old 09-20-2011, 09:53 AM
porwolf's Avatar
Bob Hutson is right. The resistors and capacitors are standard components that are always available at sites like DigiKey:
Electronic Components Distributor | DigiKey Corp. | US Home Page
or Mouser:
Mouser Electronics - Electronic Component Distributor
Radio Shack hardly caries basic electronic components components anymore.
79 SC Targa
72 T Targa Sold
68 T Coupe Sold
65 912 Coupe Sold
62 356B Coupe Sold
Old 09-20-2011, 01:31 PM
D'oh!! See user name. This was for my speedo, not my tach, although I'm having issues with that as well
Tom
Old 09-20-2011, 02:24 PM
Thanks for th links porwolf.
This looks like what I would need, I think...
http://www.mouser.com/ProductDetail/Ohmite/OA330KE/?qs=sGAEpiMZZMsPqMdJzcrNwvtkBdlAWZkzZfyLH5WDWfI%3d
Tom
Old 09-20-2011, 02:29 PM
Platinum Member
dad911's Avatar
33 ohms is a wild guess, and could damage other components.....
I'm not going to analyze the circuit from pics, but it looks like a voltage divider, and wrong value will fry other parts.
Old 09-20-2011, 02:46 PM
dshepp806's Avatar
The replacement value (resistance) has to be right,..period,..as would be the wattage rating..I'd go with the manufacturer's resistor "type" as well
Doyle
Middle Georgia
Old 09-20-2011, 04:38 PM
porwolf's Avatar
I agree with dad911, the 30 ohms I suggested as a possibility is a wild guess. And yes, Doly is right in suggesting to try to find out what the right resistor value is. Are there any other pictures of the circuit board with a picture of an intact resistor posted somewhere else? Then we could read the Ohm value from the colored rings. For instance, the resistor next to the fried one on your board looks like a 5.1 Kilo Ohm value (green, brown, red).
79 SC Targa
72 T Targa Sold
68 T Coupe Sold
65 912 Coupe Sold
62 356B Coupe Sold
Old 09-21-2011, 12:43 AM
E Sully's Avatar
This pic might help you read the 4 bands on the burned resistor, and a link for a discussion on speedometers. You can get all the parts from Radio Shack
smokey speedo
Ed
1973.5 T
Old 09-21-2011, 04:36 AM
Platinum Member
dad911's Avatar
good wild guess....
Old 09-21-2011, 05:12 AM
Thanks for the pic E Sully. That is a great help!
Tom
Old 09-21-2011, 08:39 AM
E Sully's Avatar
Your welcome. The rest of the info is thanks to Warren, early S man.
Ed
1973.5 T
Old 09-21-2011, 11:08 AM
porwolf's Avatar
Hey thanks Ed, That's phantastic. SO IT IS 33 OHMS, 1/2 WATT! Where did you get this picture so quick? I am amazed myself about the 30 Ohm, 1/2 Watt guess. So I was off by 3 Ohms!!
79 SC Targa
72 T Targa Sold
68 T Coupe Sold
65 912 Coupe Sold
62 356B Coupe Sold
Old 09-21-2011, 11:31 AM
Tags
tach circuits
