-   -   Removing frozen alternator nut (http://forums.pelicanparts.com/porsche-911-technical-forum/630763-removing-frozen-alternator-nut.html)
Christien 09-21-2011 06:15 AM
I know what you're saying - waiting for stuff to come in the mail is a pain. Count your blessing you're at least in the same country as Pelican... I'm very much of the belief in the right tool for the job, but understand that's not always an option.
In a pinch, I think the metal bar in the holes would be ok once or twice, but a screwdriver won't be strong enough - it'll just snap.
But you found the right tool anyway, so that's good.
88911coupe 09-21-2011 06:30 AM
as some have said...leverage is your friend. first time I tried this just using tool nearly tore my hand off. Added a couple of pieces of two foot pipe to the process and finally broke free. You want to make sure and not rotate the engine the wrong direction, just FYI...can cause bad things to happen.
john walker's workshop 09-21-2011 10:01 AM
Originally Posted by 86 911 Targa (Post 6265341)
Somebody posted this a while back.
http://forums.pelicanparts.com/uploa...1316562018.jpg
As for the nut, you may need a ratchet/socket,
and some type of torque amplifier on your ratchet handle.
A long pipe?
Good luck,
Gerry
that was my post. set the handle of the proper spanner on top of the motor mount tab, like in the picture. then all you have to do is use a socket and ratchet on the but.
rs6er 09-21-2011 10:19 AM
I have this off. A friend lent me the proper tools. Now that I have reinstalled the belt it is too tight. I am currently troubleshooting that.
Christien 09-21-2011 01:11 PM
Search here on shims - you should have 6, and you move them around (inside or outside the pulley hub) to adjust tension on the belt.
john walker's workshop 09-21-2011 01:23 PM
2 shims inside and a continental belt usually works. 6 total.
rs6er 09-21-2011 03:13 PM
I have a 10mm on. Fits with 4 in, 2 out. At least it does today. Make sense?
john walker's workshop 09-21-2011 03:50 PM
9.5mm usually takes two. 10mm, maybe 4, so check it again after running for a day or two.
Brett San diego 09-21-2011 04:15 PM
Ummmm... So what worked for you, besides the proper tools? Did you just need the pulley wrench alone, or did you need to use a cheater pipe on the pulley wrench? Or, did you use the wrench against the motor mount shown in the posted pic?
Brett
rs6er 09-21-2011 05:09 PM
I used PB Blaster a few times over about 15 hours. I got a proper spanner wrench (Pelican variety) and a 24mm 1/2" socket. No cheaters necessary.
It was very useful to position the spanner so it pressed against the engine mount.
