Air flow meter repair
I did a search and found one decent link to try to repair a worn air flow meter. Does anyone have any more info on this?
Thank you in advance,
John
John- 78 Slick Top 930
"Illegitimi non carborundum"
Old 08-20-2011, 06:54 AM
Member 911 Anonymous
DRACO A5OG's Avatar
Before you attempt the repair, get your DVM and 9volt battery to test if in fact you have dead spots on the arm travel.
Here you go: Rejuvenating a Bosch Motronic Air Flow Meter - YouTube
'85 Carrera Targa
PCA/POC
Old 08-20-2011, 07:59 PM
Chain fence eating turbo
What are your symptoms? How do you know you need repair?
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 08-20-2011, 08:15 PM
Thanks DRACO.
"Tippy",
I recently have unexplained hesitation with throttle input. It's on an 84 ROW 3.2 motor that has an unknown but thought to be a high amount of mileage. The problem exhibits itself early on in the acceleration (2k-3k range). I did the easy thing and swapped it out with another AFM that was known to not have any hesitation in this range. It went away, only to have a hesitations at about 4400rpm. It seems to me a safe assumption it is the afm.
Old 08-21-2011, 07:10 AM
But you still have hesitations. Might be more to it.
I'm having similar problems and went down this path too.
Good luck and please let us know the outcome.
Old 08-21-2011, 08:48 AM
dshepp806's Avatar
As to fuel: make sure you've got good pressures
As to AFM: open her up and have a look,..just don't touch that frckin' spring......look, under magnification, at the resistive trace,..it is not too difficult to make it grab fresh copper
As to ignition: all fresh plugs, dist , healthy coil...
Any of the above breakdowns could manifest your symptoms.....(good mixture, too).
BEST!
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 08-21-2011, 09:25 AM
Well the afm was replaced with two different ones including one rebuilt. I'll have to go through the list. My next guess is going to be fuel pressure. Time to break out the book. I guess a cap and rotor can hurt either.
Old 10-02-2011, 07:57 PM
Certified Pre-Owned
BGCarrera32's Avatar
Step 1 is to get access to a wideband O2 sensor and find out what the exhaust gas says about the engine at those rpm ranges...it almost sounds like your hesitation might be a lean miss. If you're north of say 15:1 that might cause a miss. Swapping AFMs won't tell you much as the base mixture screw is probably not set exactly the same form one unit to the next.
'84 Carrera Coupe
Old 10-02-2011, 08:42 PM
I'll check the afr's as well. Is there a mixture screw? It's an 84 with efi.
Old 10-03-2011, 02:54 AM
Certified Pre-Owned
There is a 3mm hex buried way up underneath the lower left corner of the AFM box as viewed when looking at the engine from the back of the car.
'84 Carrera Coupe
Old 10-03-2011, 08:12 AM
