Cold Start Valve - Testing
I'm going test my fuel pressures this weekend.
However, I suspect that my cold start injector or regular injectors are leaking or not shutting off. Basically, when the car is warm (like stopping at a gas station), startup behaves like the car is flooded. I have recently replaced the check valve and accumulator. my friend has suggested unplugging the cold start (temporarily). I'm thinking that this would have no effect if the injector is leaking - would it not still leak even if unplugged. Or, could the thermal sensor be causing it to stick on? Thanks for any responses - this is mostly for my own education on the CIS and my plan is to follow the correct steps of testing pressures and then other items. Vern |
Fleabit peanut monkey
Your pal is owned.
The CSV uses starter voltage only, WHEN allowed by the thermo-time switch. Last edited by Bob Kontak; 04-23-2012 at 07:22 PM.. |
I doubt very much that the csv is leaking, or the injectors really. You need to get a test gauge on there and find out where the residual pressure is escaping. A lot of time it's this little o-ring in the fuel distributor.
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab |
