Boge or Bilstein
Hello All
i hope anyone can help me out here
I was installing the from strut mount (weather sealed monoballs) when i discovered that the right hand side shock strut is green and the left hand side is black.
based on Pelican parts, green is bilstein and black is Boge
How can i be sure which is the correct one for my car?
thanks in advance
regards
Rudy
Old 10-03-2011, 12:29 AM
<insert witty title here>
Christien's Avatar
Make sure it's truly black and not road grime. I thought mine were boges until I found the roll pin at the bottom. The grime was ridiculously thick, and they were completely black. Hit one with some brake cleaner and steel wool to be sure.
Old 10-03-2011, 06:51 AM
yes I am sure
the BOGE word is stamped on it
thanks
Old 10-03-2011, 05:51 PM
Christien's Avatar
Well, that IS sure! Both work, if the right shock insert is purchased. I'm guessing you probably have Boge strut assemblies - there are Bilstein shocks that fit the Boge assembly, so someone probably just replaced one shock somewhere along the way at some point. You should be able to replace with either, though Bilstein is the preferred choice. If you really want to be sure, find a part # on each one and compare to the Pelican catalogue:
Porsche 911 & Carrera Suspension - Page 1
Judging by your facebook pics, I'm assuming you're driving a 3.2 Carrera. Might be a good idea to list your car in your sig, to avoid confusion .
Current: 1987 911 cabrio
Past: 1972 911t 3.0, 1986 911, 1983 944, 1999 Boxster
Old 10-04-2011, 02:21 PM
dshepp806's Avatar
I've remained the bastard child,..as I just installed Boges on the rear (factory) and will soon load Boges on the front, as well.......want to keep her this way.....all will be fine.
BEST!
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 10-04-2011, 05:06 PM
