turn signal problems
I'm having an a problem with my turn signal/emergency flasher not working. They work, then they don't, then they work again. I have an 84 carrera. I have replaced the flasher unit, the turn signal switch, the headlight switch, and installed a headlight relay to protect all of these switches from an early death. The turn signals seem to work for an application or two and then they don't. I check the emergency flashers and they fail at the same time. I was told that the emergency flasher switch may br the culprit, but it was replaced about 4 years ago. Any suggestions would be appreciated.
Old 10-01-2011, 06:26 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Do you have a Bentley, and a multimeter?
Intermittent open ground is highly suspect.
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 10-01-2011, 06:40 PM
muck-raker
kidrock's Avatar
at first, I thought it would be the typical turn signal switch issue, which is very common.
But then you added that you are having a similar issue with the emergency flashers as well, which is a different switch altogether.
I agree with Gerry....ground or maybe even a bad relay?
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 10-01-2011, 07:05 PM
porwolf's Avatar
Do you mean the "emergency flasher" that turns the high beams on by pulling the turn signal arm? I had a similar problem on my 79 SC. What happens is that the high beams went on automatically every time the turn signal switch is returned to the center position after completing a turn. The problem has to do with some of the contact springs inside the switch. I took it apart and bent those springs to prevent it from happening. At least it worked for while.
79 SC Targa
72 T Targa Sold
68 T Coupe Sold
65 912 Coupe Sold
62 356B Coupe Sold
Old 10-01-2011, 07:55 PM
Recreational User
porschenut's Avatar
Nope, he's talking about the flashing hazard lights.
Poor ground connection is a likely culprit.
Old 10-02-2011, 06:51 AM
I recently had an intermittent turn signal. Turned out the wire was loose in the fuse block. I didn't think those could work loose and didn't look there right away. It's worth checking ...
Dave
1985 Factory Turbo-Look Coupe
2011 Cayman S
2012 Audi S4
Old 10-02-2011, 08:54 AM
i have the same problem now and it is the left rear bulb that grounds and then it does not. I am ready to solder a ground wire to the bulb!!
RGruppe #79 '73 Carrera RS spec 2.7 MFI
00 Saab 95 Aero wagon stick
01 Saab 95 Aero wagon auto
03 Boxster
90 Chevy PU Prerunner....1990
Old 10-02-2011, 09:03 AM
Send a message via Skype™ to Porboynz
If both the hazards and the horn stop working then its fuse #2 and maybe its the copper link between fuse #1 and fuse #2 in behind the fuse panel is intermittant. It happened to me.
See a picture here:Its Alive!!
1972 911T Coupe with a '73E MFI engine and 'S' pistons
10 year resto mostly completed, in original Albert Blue.
***If only I didn't know now what I didn't know then***
Old 10-03-2011, 12:51 AM
I too had a recent intermittent problem with my turn signals. After swapping out the relay and the switch (both new now) I found I had a faulty fuse. Darn thing looked fine, but fell apart in my hands when I pulled it to check for corrosion at the fuse panel. I would start at the panel as the previous posters suggested. Look for a corrosion and loose connections, put in a new fuse.
Old 10-03-2011, 05:26 AM
