Help needed - Clutch helper spring
In trying to replace my clutch helper spring so that my wife can drive the car while I'm gone (deploying to Kandahar in two weeks), I'm a bit stuck.
Pulled the old broken spring off, reassembled the arm, and everything appears ok . But, in the process of reassembly I've got a few problems:
- the clutch pedal was depressed, and now is flat on the floor;
- the new spring is physically larger than the older, and I cannot get it to seat, so cannot get the arm back into its seemingly correct position;
- I'm not sure if, once the arm is seated, if the clutch itself will function....
Basically, I'm stumped, and could used some "real time" help!
Old 10-01-2011, 11:14 AM
Here's a pic of where I am - Thanks!
Old 10-01-2011, 11:16 AM
E Sully's Avatar
You seem to have the spring on wrong, flip it over. Here is a pic of the correct setup.
Ed
1973.5 T
Old 10-01-2011, 12:44 PM
E Sully's Avatar
A few extra details for adjusting.
Ed
1973.5 T
Old 10-01-2011, 01:13 PM
Ahhhh, thank you. I'll flip it tomorrow morning - much appreciated!
Old 10-01-2011, 05:34 PM
Detached Member
Hugh R's Avatar
Make sure the spring is against the heat exchanger, when flipped, it will also go in another position which you can rectify with a large screwdriver.
Hugh
Old 10-01-2011, 07:23 PM
Magic. Thank you gentlemen.
Old 10-02-2011, 08:14 AM
