old man neri's Avatar
Battery draw, I have isolated the fuse but.....
Background:
I was away from home for a month, come home and the battery is weak, not strong enough to start the car but it does turn it about half a crank. I jumped it and went on my way to work. End of the day from work get in car, turn key, starts wonderfully.
Next morning....nothing, not even enough to keep the clock going. A totally dead battery.
I suspected a draw and I found one. Fuse/Relay panel 1, fuse 1. Bentley says it's the Clock, glove box light, luggage light, and interior light. With all of these disconnected I still get 0.5 amps draw. With the fuse out I get no draw.
Help.
PS the clock seems to draw .2amps, is that normal? Or is that due to the fact I am running it with lower than normal voltage.
Old 10-07-2011, 12:31 PM
Gary H 1978 911 SC
The clock might draw 30 ma not .5 amp. You still have something making heat, could be a stuck light burning (check at night with no other lights on) . I have seen a jamed CD player draw .5 amps and whipe out a battery. Check for a warm relay that is stuck on. Something is drawing that .5 amp and you have to find it.
Old 10-07-2011, 12:51 PM
Alright, found the problem. Basically, I am an idiot.
1) I looked up the wrong page in Bentley, for my year it also lists the radio. The radio was drawing 0.5 amps. .1 when my ipod wasn't plugged in. I guess it charges it all the time.
2) The clock only draws 0.2 amps when it is plugged in backwards which is exactly what I did when I plugged it back in.
So I am guessing (hoping) that the reason it died overnight was that I left something on (headlights, turn signal...etc)
We shall see. Right now it only draws 0.12amps when all is plugged in (minus the dead ipod).
Old 10-07-2011, 01:05 PM
Gary H 1978 911 SC
I think you still have an issue. How accurate is your meter? 120 ma will drain your battery over several days. Something is still creating a warm spot.
Old 10-07-2011, 01:25 PM
It's only the radio that seems to draw it. My meter is about $30 accurate.
Old 10-07-2011, 01:44 PM
First recharge your battery correctly so you have full charge, the alternator will not completely recharge a dead battery unless you take a 12 hour drive.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 10-07-2011, 01:47 PM
On a borrowed battery charger as we speak. The battery is disconnected as well.
Old 10-07-2011, 02:06 PM
What year?
Dome light and ???? (frequency valve maybe? if you have CIS - not sure) is on the same circuit.
Old 10-07-2011, 02:56 PM
1988
Old 10-08-2011, 08:09 AM
Standby "spec" draw should be no more than 16 milli-amps.... 16 mA....... for the 3.2's
Pull the light bulb either in the glove box light or the trunk light....then check again.
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 10-08-2011, 08:57 AM
I had the very same dead battery problem as you, a couple of months ago. Drove me nuts, day after day a dead battery! I had somehow inadvertenty left the glovebox/map light three position switch in the "always on" position! Never noticed it because I only drove the car during the day. Walked out one night and saw a faint glow in my interior. Voila!, problem solved, and I felt like a real dumba**.
'80SC Widebody 3.6 transplant Anthracite "The Rocket"
Long gone but still miss them all:
'77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!)
'71 911T Coupe White, '70 911T Coupe Blue
'68 911 Coupe Orange, '68 911L Soft Window Targa
Old 10-08-2011, 09:25 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Battery drain.
Originally Posted by old man neri View Post
1988
According to the Bentley, 0 to 100ma is normal residual drain.
400+ ma would indicate a problem.
Assuming you have the "boat anchor" 80A battery,
in good condition, a drain of .5A would deplete the battery in about
160 hours.
100ma would drain your battery in 800 hours.
However, long before those numbers, your battery would not have the cranking
amps to start the car.
pm me as needed.
Good luck,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 10-08-2011, 09:56 AM
Platinum Member
dad911's Avatar
How old is the battery, running it down might have killed it.
Old 10-08-2011, 10:28 AM
Send a message via AIM to morrisjm1 Send a message via Yahoo to morrisjm1
Not sure if it applies to an '88, but here's what I've done...twice. On the '78 there is light under the dash above the glove box knob, the switch that is either, OFF, On, or Switched to operate with the door switches. I keep the garage door opener in the glove box I have accidentally moved the switch to On while opening/closing the glove box. In the day time, you don't notice the light is on and if you don't go into the garage when it's dark and see it glowing and turn off, it will kill your battery.
Mike
'78 911SC Targa (SCWDP member #17)
'74 MGB (one owner)
Pickup
2013 Ford Explorer Sport
2013 VW Golf TDI
Old 10-08-2011, 01:50 PM
