Stahlwerks.com
jhelgesen's Avatar
Send a message via Yahoo to jhelgesen
Aftermarket 3.2 ecu
Read in one of the UK magazines about a shop building new ecus to replace the motronic for the 3.2. Offered data collection and direct tuning, then could be combined with a few other intake goodies.
Anyone else recall seeing these, or tried one?
Old 10-07-2011, 06:30 AM
Chain fence eating turbo
Exactly what is needed!!!!!!!
You can diagnose these cars in about 5 minutes instead of 5 months.......
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 10-07-2011, 07:09 AM
Sub'd
Old 10-07-2011, 07:10 AM
I like to watch.
Old 10-07-2011, 08:25 AM
Lorenfb's Avatar
"ecus to replace the motronic for the 3.2. Offered data collection"
Actually, the 3.2 DME ECM has the data acquisition electronics but just
needs the firmware to do the diagnostics.
Have Fun
Loren
Systems Consulting
Automotive Electronics
'88 911 3.2
'04 GSXR1000
'01 Ducati 996
'03 BMW BCR - Gone
Old 10-07-2011, 09:04 AM
Listening...
Old 10-07-2011, 09:08 AM
Loren, how does someone change the firmware?
Cost?
Old 10-07-2011, 12:13 PM
Northern, CA
Similar Thought
Is it possible to download the table from the data acquisition component to a PC for further analysis? Does a map of that component exist to assist in comparing actual values seen by the ECU to expected values?
Could this then be used to write a program for further data analysis and tuning and eliminate the need for hard coded firmware?
1989 Carrera Coupe
Old 10-07-2011, 02:40 PM
Lorenfb's Avatar
"how does someone change the firmware?"
1. Read & disassemble the chip program
2. Modify the program to read & test the sensors
and monitor the ignition & injectors and store the
actual values with any faults
3. Re-assemble the modified program and program
the chip
4. Make a code reader, e.g. 964/993/928 Bosch Hammer,
to interface with the 3.2 DME ECM
Porsche most likely had a chip during the 3.2 development
that could do diagnostics but they didn't include it in the final
production 3.2 DME ECM. The test connector to access the
ECM is in the engine compartment.
Bottom line: Not a simple task, i.e. many man-months of development time!
Have Fun
Loren
Systems Consulting
'88 911 3.2
'04 GSXR1000
'01 Ducati 996
'03 BMW BCR - Gone
Old 10-07-2011, 08:29 PM
