Engine # help...
Can someone give me info on the basis for an engine # 6272XXX ??
Thanks |
RETIRED
76-77, 911S, engine#911/85.....2.7 and 165hp.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Thank you Joe Bob.
It is now a twin plug, 2.8, MFI... Looking to find out more about how it was built and with what components.... |
I bought an 1982 SC recently but it has a Cab engine. Can someone tell me what year/model this engine is from? #64C1870
RETIRED
81-82, 3.0
Insert Tag Line HERE.....
Thanks guys. I appreciate it.
While the engines were the same, according to my mechanic and to my driving instructor, we can tell the engine was from a cab due to a shock absorber on the engine mount. |
83 911 Production Cab #10
If your 81-82 engine has a cab bracket, it was a mod as the Cab (and the damper fitted bracket) started in 83.
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger Last edited by JJ 911SC; 10-09-2011 at 04:27 AM.. |
Oh cool. Thanks for that info. Then I bet I have the original engine with a vibration damper added as you suggest. What benefit does reduced vibration in terms of performance?
By the way, JJ 911SC, is that a pic of your engine? Impressive... |
SS
Thanks. Yeah, a few $$$$ and 5 months of not riding ![]() ![]() ![]() Back to the performance, If your car is a coupe having a damper will not do anything. The damper is to limit the effect of the flex of the cab, on the engine. What year/model is your car?
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
Mine is a 1982 911 SC. Been through a couple owners but we can trace it back to an owner in New Mexico. 72k mi.
I wonder why a previous owner may have put the damper on? |
Well, the engine has travel, before fitted in your car.
The only way you can confirm that it is the original fitted engine, is to get a Certificate of Authenticity from Porsche ($110). If its a Targa, one of the PO might have think he could make it more rigid.
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger Last edited by JJ 911SC; 10-21-2011 at 02:09 AM.. |
Hey JJ what does this mean? "Well, the engine has travel, before fitted in your car."
Sorry about the typo; I should have said "may have travel". If you get a CoA and the engine does not match it mean it could have been fitted in a cab at one point. If it match the CoA, now you got to find out where/why it was fitted. I think it would be worthed to spent that $110. What month was the car produce (on the door VIN sticker).
