Joe: Doesn't ES-12 give you some sort of conversion? I'd imagine that if they did, all you'd have to do is "tweak" the amount a bit after the initial charge.
1984 Targa |
Senior Member
Found it on the page you sent me to. How efficient is ENVIRO-SAFE
"For those who install by weight, the equivalency ratios are: .33 lb. of ENVIRO-SAFE ES-12a is equivalent to 1 lb. of R-12" The 911 came from the factory with about 4 pounds of R-12, so my guy is spot on with 1.5 pounds of ES-12.
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
