1974 911 w/ 83 SC engine
Torque'd the starter stud right out!
Well I almost did it, almost got the engine and transmission put back together without a misstep. Almost.
I installed a mini hi-torque starter as part of the whole project, and as I was torque-ing the engine to transmission nuts (30ft.lbs.) I noticed the second starter barrel nut seemed to take longer to torque than the others. Something wasn't right. So I undid the barrel nut, along with the top barrel nut and tried to take the starter off to see if something wasn't seated right. This is what happened:
The whole stud came out, leaving this:
So I took this:
Ground it down to this, to fit in the back:
And installed it like so:
I know this wouldn't be the optimum fix; but torqued to spec, does anyone see an immediate reason why this wouldn't work?
Oh, and if I've learned anything in the last hour, it's that I've eaten cheeses harder than freaking magnesium. Thanks guys!
Old 10-13-2011, 05:30 PM
Quantum Mechanic
mpetry's Avatar
Send a message via Yahoo to mpetry Send a message via Skype™ to mpetry
Looking at the pics, has that mounting "ear" been cracked / split and TIG welded for repair before ?
Mark Petry
Bainbridge Island, WA
81 SC
Old 10-13-2011, 06:09 PM
Walt Fricke's Avatar
Looks like a good fix.
Doesn't your bell housing look like it has been welded upon? Including where this stud went? It looks like that repair included a Helicoil or something with a similar function, which backed out or pulled out.
Several of my engines have had a Helicoil where the engine studs are held to the engine case. I don't know if that is factory standard, or indicates a repair. All have worked fine for me, happily.
Old 10-13-2011, 06:15 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Oh man HWM! Sorry to see that brother!
Glad you rigged somthing up to cure it. Lucky it was the bottom on e not the top, it would be a complete biotch to service the starter in the future if it was the top barrel nut.
Jim
'85 Carrera Targa
PCA/POC
Yeah, that's exactly what it looks like to me too. You can see the weld go all the way around the mini "bell housing" for the starter. It was quite the surprise for me the first time I dropped the engine and tranny, that big weld line.
Old 10-13-2011, 08:31 PM
