Oh No! Key Can't Open The Door
Need some advice on this one before I tear something up.
When I put my key in the door lock and turn it, it no longer raises or lowers the door lock button. It just rotates freely.
Does this mean my entire handle has to be tossed or is there some mechanism inside that can be replaced, adjusted, or fixed? The handle still opens the door when compressed so that functions.
The door lock button lifted or lowered manually still locks and unlocks the door, so I know at least thats functioning. Help!!
Bob
1973.5T
Old 03-21-2002, 07:30 PM
the screw that holds the locking "lever" to the end of the tumbler has backed out and the lever is loose. remove the handle to fix.
206 637 4071
Old 03-21-2002, 07:41 PM
Hilbilly Deluxe
emcon5's Avatar
What John said. Same thing happened to me right after I bought my SC.
Tom
82 911SC Coupe
GTI Cup #43
Old 03-21-2002, 07:57 PM
Wink
Sunroof...as long as your going in there you may want to consider the window regulator up-grade. maybe $25
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 03-21-2002, 08:00 PM
BKOMAR's Avatar
Send a message via Yahoo to BKOMAR
My key will UNLOCK the door... but will not LOCK it. It is kinda embarrassing that I have to come around to the passenger side and crawl in to lock the door and then lock the passenger door from the outside. Any suggestions? Thanks, Brian
75 914 2.0L
73 914 2.0L X2
73 914 1.7L X3
71 914 1.7L
87 944S
1987 SAAB 900 Turbo
80 Euro 911SC
1980 Yamaha XT500
Old 03-22-2002, 11:34 PM
