Scott R's Avatar
Using back dated oil lines with SC exhaust
Can I use my original heat exchangers with my backdated oil lines? I have a temporary need to install my original exhaust but I don't have all of the original lines anymore.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 10-20-2011, 06:05 AM
Diss Member
Quicksilver's Avatar
No, the exhaust interferes with the early lines. The solution is to use the Elephant Universal Crossover line. It routes over the trans which means you can swap back and forth with no issues.
Porsche 911 & Carrera Oil Circulation - Page 5
I put this on my 87 car which was a bit more difficult as the G50 has to have a rib ground down to clear the line but the ability to swap the exhaust at will is well worth it.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 10-20-2011, 06:20 AM
vinny c's Avatar
+1 for the universal line. After smog test, it was a easy putting SSI's back on.
Old 10-20-2011, 11:31 AM
