Dead speedometer 1969 911
Just picked up my new 69 last Friday and was driving home when I noticed the speedometer was no longer working. For the first 100 miles it worked fine. Thoughts, advice and recommendations are greatly appreciated.
Old 10-23-2011, 08:59 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Congrats! On your new baby
1st is it a cable or electronic Speedo, I am thinking that era would be cabled, If so it may have dislodged behind the speedo or at the trans. The cable may have shredded apart as well.
Simple enough fix, I just recently fixed my son's 190E Speedo cable
'85 Carrera Targa
PCA/POC
Old 10-23-2011, 09:05 PM
kkinzli's Avatar
Congrats! 69 is the way to go! Originally your car should have a cable. If you search this forum there is a great write up on how to replace. I would suggest getting the cable from North Hollywood Speedometer as all of the other available cables are too long and will kink. Don't ask me how I know They will custom make one for you for around $75. When you are replacing the cable make sure to tie a string to it as you pull it out of the tunnel. This will make it easy to install the new one. Also don't forget the two tabs that hold the cable in the tunnel. Good luck!
1969 911T - The "Rat"
1997 A4 Quattro 2.8 (270k) - Black Kaniget - Dead but not forgotten
2010 Jetta TDI Sportwagen - Egg Butt (also Spewing Dragon)
2001 Eurovan Weekender - Bruni
Old 10-24-2011, 05:03 AM
