can anyone tell is this boge stut
hi can anyone tell is this a boge ? thanx
Old 10-23-2011, 12:23 AM
Member 911 Anonymous
DRACO A5OG's Avatar
Black, sure looks like it
'85 Carrera Targa
PCA/POC
Old 10-23-2011, 02:09 AM
thanx , i just want make sure before i order new one
Old 10-23-2011, 02:39 AM
Black is the normal color of Boge but struts can be painted. On my 944 & 914, the Boge struts had "Boge" stamped into the metal, near the bottom. It can be a very faint stamping and hard to see but I would look for this (or try and feel for this on the backside) just to be sure.
Old 10-23-2011, 04:19 AM
ivangene's Avatar
looks Boge - what inserts are you going with?
Ed M
86' Coupe
Old 10-23-2011, 08:12 AM
Clean the road grime off the strut and look for the word BOGE stamped on it. Tidy is correct in that Boges are black or grey but any strut can be made black. I put Bilstein inserts into my 68 because the Boges are no longer available for SWB. I'm please with those just be sure to check for foreign objects inside the tube and whether your application needs a spacer or not
Old 10-23-2011, 09:20 AM
RETIRED
Joe Bob's Avatar
Green is Bilstein but can use a Koni insert.....black is usually Boge.
2012 ML350 3.0 Turbo Diesel
Old 10-23-2011, 10:22 AM
redridge's Avatar
look closely.... there should be a Boge engraving on there.
Old 10-23-2011, 11:34 AM
ye i want to put bilstein sport insert in to it .i will have look at it .
Old 10-24-2011, 05:09 AM
