Administrator
Jack Olsen's Avatar
Decklid shocks -- the permanent solution
Since my car has a lighter-than-stock fiberglass front lid, and three different rear decklids, which range in weight from light (fiberglass ducktail) to heavy (964 retractable), I needed a very flexible decklid-raising solution. Dave Bouzaglou at TRE Automotive came up with the idea of using prop bars instead of the gas-loaded shocks. It's a solution that saves me some weight and will never wear out.
Here's a picture of the rear bar, raised:
Here's one of it lowered.
In front, here's a shot of it tucked away, with an insert of the upper mount.
The advantages are numerous. Air temperature doesn't cause me headaches. The things don't wear out, and a heavier or lighter load doesn't require alternating between one or two shocks. Also, a single shock in the rear (stock on the earlier, lighter lids) puts constant pressure on one side of the lid, which means more fine-tuning to make sure the latch stays shut and the lid closes evenly. With the prop bars, none of this is a problem.
Old 03-23-2002, 02:54 PM
Administrator
Jack Olsen's Avatar
This may be a better view:
Old 03-23-2002, 02:58 PM
Not Quite Banned
Thomas Owen's Avatar
Jack - watch out for the wind getting under the lid and allowing the arm to drop. I had this happen on my first 911 when I was under the rear lid using a 'prop bar'. Maybe you could come up with some sort of a socket fitting that would resist someone bumping the lid or the wind. Good idea though...
Regards,
Thomas Owen
1972 911T
1972 911S
Thanks for the pics Jack. I will be going to the prop type when I replace my front hood with a fiberglass unit.
Old 03-23-2002, 05:21 PM
pwd72s's Avatar
Jack, Jack, JACK...you do have too much time on your hands. Ever heard of a broomstick, a hacksaw???????
Old 03-23-2002, 05:24 PM
NOW YOU STARTED IT.I PUT NEW CYLINDERS ON BUT THEY WILL NOT SUPPORT THE HOOD AS I HAVE THE CIBIE LIGHTS ON IT.I HAVE BEEN TRYING TO SOURCE STRONGER CYLINDERS BUT FEARED DAMAGING THE HINGES. THIS WILL SOLVE MY PROBLEM. BACK TO THE IGLOO ROBIN.
THANKS
WOODY
KEVIN WOOD
70 911E TARGA
Old 03-23-2002, 05:27 PM
pwd72s's Avatar
Woody..I repeat..ever heard of a broomstick and a hacksaw??? Not only effective, but lighter when you're on the track, assuming you left the broomstick in the pits. As a guy I once knew who designed lumber mills once told me...don't try to redeign the paddle wheel...it works.
Old 03-23-2002, 05:34 PM
Administrator
Jack Olsen's Avatar
Actually, I'm going to disagree with Paul on this one.
I used to use the broomstick. The not-so-bad downside is that it tends to get misplaced or left behind. The worse downside is what happens when you're leaning way in there, and you bump it with your shoulder, and the lid comes down on you. I'll grant that the broomstick involves less fabrication, but the prop bars generate fewer lumps on the noggin.
Old 03-23-2002, 05:43 PM
pwd72s's Avatar
Hey Jack..I'm not disagreeing with you. I was merely offering a stone age alternative.
Old 03-23-2002, 05:50 PM
