bolt size of 72 steering column clamshell
Hello,
I need to get the bolt specs (thread #, length, etc) for a 72 steering column clamshell. My current one is rigged up correctly and I bought a replament one but the bolts were not included. TIA, Scott
72 911 T Targa in Orient Red / Black - more like a 85 Euro RS IROC now - 85 Euro 3.2 with x-faktory EFI ITB + SSI + Dansk, 915 + Wevo, flares + IROC bumpers + duck tail, RS door panels, Corbeau LG1 microsuede seats, Speedware harness bar + drop links + Scroth DOT harnesses, adj Tarett sways, sport shocks, alloy trailing arms, Elephant Racing oil lines + spring plates + bushings, RSR Rota Foxes + Bridgestone S-04 PP, 2450 lbs |
If you are talking about the plastic covering. It is held on by 4 screws M4x10 that affix to the horn ring and two very small screws AM3 x10 on either side. No bolts that I know of.
1973 911S (since new) RS MFI specs 1991 C2 Turbo Last edited by RSTarga; 10-24-2011 at 12:06 PM.. Reason: size addition |
Thread Tools | |
Rate This Thread | |
