Okay it looks like I have been able to confirm these will fit on all models up to 1986 as plug and play. You must have your stock H4 plug for our kit to be plug and play on your vehicle.
http://i.imgur.com/ZDw4Ml.jpg |
subscribed.
Linc for your high end über car you need something more with a little more flair than a 7 inch sugar scoop replacement
Just an observer, I want to see where this goes.
I believe this rolled over to several threads but this was the ultimate result.
Porsche 911 - Classic Style Headlights | Dapper Lighting |
"This" is what you are buying. Two of these... Just don't be a ricer and hook up the angel eyes. And...everything can be mounted inside the existing headlight bucket. Below are base 7" headlight assembly, lens to be heated, removed, and re-installed in accordance with kit. |
http://forums.pelicanparts.com/uploa...1360174760.jpg |
*** Speaking of which, you do not make it clear as to which hi/lo approach your kit uses, bulb base solenoid or integral apperture? |
Same price. |
To answer your other question: "Internal Aperture" or shutter type. I've never seen a projector that requires a bulb base solenoid.... |
Solenoid in HID bulb base tilts arc to/from hi/lo beam position.
http://forums.pelicanparts.com/uploa...1360176838.jpg http://forums.pelicanparts.com/uploa...1360176983.jpg http://forums.pelicanparts.com/uploa...1360177037.jpg http://forums.pelicanparts.com/uploa...1360177102.jpg |
What did you mean "bolt" vs OEM..? "bolt-on"..? |
They make projectors that have a threaded end designed for retrofitting. You can "bolt" them into a cutout housing rather than mounting an "OEM" style projector that you have to epoxy/tape/glue whatever it may be. http://i.imgur.com/oM2sa0ol.jpg http://i.imgur.com/wRhvMHhl.jpg |
Seems like WWEST is also the resident expert in these. Laughable. what an idiot. Every new thing that actually works.. he posts "the Fool is parted with his money" post... Dapper... carry on. Ignore WWEST. If you want to know more about him, do a search. Its quite entertaining... not surprised to see an ebay pic/link. LOL
