-   -   Anybody want to try a projector headlight kit for 911? (http://forums.pelicanparts.com/porsche-911-technical-forum/636502-anybody-want-try-projector-headlight-kit-911-a.html)
donporfi 08-28-2013 05:54 PM
just to prove that the H4 and the clear lens are the same size, the H4 lens in the 356 ring.
http://forums.pelicanparts.com/uploa...1377740767.jpg
Soterik 08-28-2013 08:39 PM
I think there's a little bit of clarification necessary here. You don't need to get a 356 assembly. You would simply need the early 911 (65-67) version of this headlight assembly "guts", the new headlight trim rings are available from our host (I made them), and you can purchase new correct Hella glass from me for about half of what the typical suppliers have them for, OR go even less expensive on the glass and get the clear glass with no manufacturer stamping from the VW guys (yes it fits).
Here's my trim ring (made out of brass like OEM, then triple chrome plated)
Pelican Parts - Product Information: AFS-631-933-00
You can buy the early 911 headlight "guts" from EASY in Emoryville CA, or Parts Obsolete in McMinnville Or. My headlight rings come with all the adjusters, and new springs.
There's a few threads about doing inexpensive versions of these headlight assemblies on the Early S, and 912 forums using VW parts (if you just want to give it a go with a low inventment).
cheers,
Eric
froggert 08-29-2013 06:19 AM
i have something similar on my car. apologies for the poor pic:
http://forums.pelicanparts.com/uploa...1363500341.jpg
donporfi 08-29-2013 09:15 AM
Eric is right a clarification is needed.
If you want to adapt these reflector headlamps to Euro H4 assemblies you will need the "guts" of any sealed beam assembly from a 356, early SWB 911/912 or VW ( I am not sure if early VWs used these).
These are the parts needed:
http://forums.pelicanparts.com/uploa...1377796213.jpg
If you already have early 911/912 sealed beam assemblies, you will only need the reflector headlamps.
