Motor rebuild complete - looking for dyno advice
Just finishing motor rebuild. Dam, those PMO carbs are a beauty to look at! Any advice on dyno time and do's/don'ts? Is it worth the money to reserve a day for this? Thanks for the info.
Looks purdy!
I read an article this week on Dynapack hub dynos, which are available in the US from Ultimate Garage - the website is www.dynapack.com. I suggest it because (a) it is a NZ product (b) I will be getting my car run on it when the Motec is fully dialed in, in a month or so and (c) because it is apparently much much better, more accurate and mechanically sympathetic than a chassis dyno.The negatives are that it requires a longer setup time and is not cost effective for a quick run. Check the websites - it is pretty cool.... I will give a full report in a month or so when my car is run on it. Cam
1975 911S (in bits) 1969 911T (goes, but need fettling) 1973 BMW 2002tii (in bits, now with turbo) |
Do the Dyno !!
It is worth the money.Make sure you properly warm up your car before the run and try and find a shop that has done Porsches and knows what they are doing.Beautiful motor !!! Congratulations ! Be sure to let us know how you make out. |
