911 broke down last night major oil spill
Can anyone help pls
My Porsche 911 997 2006 with very low mileage broke down last night and dropped all it's engine oil. I recently had it serviced so am wondering if someone has forgotten to put a cap on somewhere. Just wondered what I was facing before the garage take a look. breakdown down truck tried to put more oil in but it went straight through. It had made a small noise minutes before like I had run over a small branch or twig which was not the case.
Would appreciate any comments/suggestions
Old 10-30-2011, 05:41 AM
Hodgey's Avatar
Firstly, welcome to Porsche World......sorry to hear your plight
Any pics of the car or the affected area?........usual courtesy is to supply pics with first post
Neil
Neil
1987 Carrera, Grand Prix White, 2009 Carrera C4S, Meteor Grey Metallic
(X) [B] 2011 BMW X5[B]
'Success is not final, failure is not fatal. It is the courage to continue that counts'
Old 10-30-2011, 05:48 AM
Hi
Would not really know what to take a picture of ?
Old 10-30-2011, 05:58 AM
Apparently leak is between engine and the gearbox - does anyone have any ideas pls
Old 10-30-2011, 06:12 AM
redridge's Avatar
sounds like an IMS/RMS.... I would not start the engine, get it towed to the dealer if warranted. 2006 has the same design with 99-05 that has similar issues. The engine and tranny needs to be separated.... if it dumped oil all of the sudden and made noises most likely it is the IMS bearing and can be pulled out and upgraded.... hopefully the shaft is still good
Old 10-30-2011, 06:15 AM
Northern Motorhead
wildcat077's Avatar
Well you have a crank seal between the eng and gearbox,right behind the flywheel but i doubt very much it would dump the oil out at that rate ...
Could also be that you lost your drain plug due to the mechanic forgetting to tighten it properly...
Like Neil mentioned,pictures are worth a thousand words !!!
You might have more luck posting on a newer 997 forum ...
Cheers !
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 10-30-2011, 06:17 AM
Assuming you were driving what triggered you to pull over? Light on dashboard or loss of engine power?
1983 Porsche 911SC - Arrow Blue lightweight '74 Carrera look
http://forums.pelicanparts.com/porsche-911-technical-forum/498568-overdue-intro-sc-hotrod-project.html
Old 10-30-2011, 06:18 AM
KNS KNS is offline
Agree with redridge. Sounds like your IMS bearing (Intermediate Shaft), if you're not under warranty you're buying a new engine (I hope I'm wrong..).
Post over on the Rennlist website (997 forum). Many more 997 owners over there.
Kurt
Old 10-30-2011, 06:57 AM
Guys - thank you all for your responses, much appreciated. Given I can not get under the car to take a picture I have decided it is one for the Porsche main dealer about 4 miles away from me. Once they tell me what the problem was I will share it with you - it does though sound like the IMS.
Old 10-30-2011, 07:01 AM
Northern Motorhead
wildcat077's Avatar
For some reason i always thought the IMS/RMS issues were only common to the 996's and were addressed for the 997 models ...
Cheers !
Phil
Cheers
Phil
Old 10-30-2011, 10:45 AM
Chain fence eating turbo
Unfortunately, the 997's suffer IMS failures too.
Don't want to be negative but the fact you had a sound minutes before the spill more than likely indicates the IMS sealed bearing dried out and froze up.
I hope I'm wrong though!!!!
Good luck!
Old 10-30-2011, 10:50 AM
