Question installing Cylinders
I've read two books one states to wet the copper gasket with case sealer the other one says don't -- ok guys which is it?
Old 03-23-2002, 10:20 PM
Senior Member
Superman's Avatar
I wet mine with copper coat gasket dressing. Not case sealer. If you're just putting cylinders on, then you will be installing more gaskets. Might make sense to use gasket dressing stuff.
Mocha 1978 911SC. "Coco"
Old 03-23-2002, 11:44 PM
Senior Member
Zendalar's Avatar
Er...dressing? Is it like copper paste? What about the top gasket should I put something to the aluminium gasket?
Old 03-24-2002, 10:44 PM
1-6-2-4-3-5
Send a message via ICQ to zuffenhausen Send a message via AIM to zuffenhausen
The copper base gaskets should be installed dry. What aluminum gasket are you talking about? A head gasket?
Old 03-24-2002, 11:47 PM
Senior Member
Zendalar's Avatar
yes, the head gasket. But youre saying those gaskets should be installed dry? Is there a wrong way to install those ? I mean can you install the gaskets ...well, upside down? (Does it matter?)
Old 03-24-2002, 11:51 PM
1-6-2-4-3-5
What engine are you working on that uses a head gasket? I've never worked on a 911 engine that used a head gasket but I'm confident you should install those dry as well. There's no gasket goo I know of that would survive there.
As for the base gaskets, it doesn't matter which side is up, but there should be four little cut-outs which are there to clear the head studs. It's sometimes a little frustrating to keep them lined up. Also, double-check to make sure you have the same number of them under each cylinder.
Old 03-25-2002, 12:09 AM
Senior Member
Zendalar's Avatar
HMm, "aluminium rings" that are located between cylinder and cylinder heads are not gaskets? copper rings should have openings for head studs? They are round rings that are not in the way of head studs.
Well, I suppose i install them dry.
Old 03-25-2002, 12:35 AM
Senior Member
Superman's Avatar
Although most are installed dry I suppose, yes you can use gasket dressing on the copper cylinder base gaskets. Those are the ones with the holes for head studs to go through.
At the top of the cylinder is an aluminum sealing ring with a tiny spring inside it. Don't use anything on this.
Old 03-25-2002, 08:15 AM
