Senior Member
Big Leak
Oil is dripping down the back of my right chain cover. Dripping profusely. I took both valve covers off and verified that the rocker shafts are still in place. I think this means I need to remove the cam retaining plate and check the gasket and the big o-ring. I can see the gasket, so I apparently did not forget this, but perhaps I neglected to torque the three little bolts.
Anybody disagree with my conclusion that this cam retaining plate is where the oil must be coming from?
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
Jim,
That sounds about right to me. the bolts could not be tight or maybe the o ring is pinched or something. You remembered to put the the gasket on right?
Michael |
No disagreement here. Seems fairly likely! I'm sure the retiming will go smooth this time ...
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
Senior Member
Yeah. The gasket's on, I can see it. I agree with you, a pinched o-ring or bolts that were not tightened. I may have to fire my sidekick over this. Wait a minute. Superman doesn't have a sidekick to blame stuff on.
"Pay no attention to that man behind the curtain."
B58/732
If it makes you feel better you can fire me if you like.
I'm not doing anything around here anyway.
ΜΟΛΩΝ ΛΑΒΕ I don't always talk to vegetarians--but when I do, it's with a mouthful of bacon. |
Superman,
Same thing happened to me when I did mine, not profusively but it leaked. Take the cam plate off, remove the gasket and oring, seal them with some sealant and retighten to spec, that will do it. Effing Pain in the Butt if you ask me. |
better that than the #8 o ring!
Schleprock
Just kidding. I know, just saying it's an easier fix than the #8 nose bearing.
Kevin L '86 Carrera "Larry" |
Kevin, are you playing around on the I-net at work again?
I found some big holes on the way home the other day, You gonna make someone fix em! Hey if you want need any help putting your front end back together, let meknow, I'd be happy to help if I can get away for a day. Dennis H. 72 911E |
Schleprock
Thanks Dennis. Should go together pretty straightforward, but if I need a hand i'll let you know. Might need some help squeezing that sway bar back in!
By the way, just killing time "on lunch."
Senior Member
Thanks dudes. You're fired, Blue Sky.
(knock on wood) this engine leaked in many places before this project, including cylinder bases....many places. There are no 'case' leaks and there also appears to be no 'head' leaks. My fingers are crossed in hopes of a leak-free engine. I think I have a gasket and o-ring lined up for tinight, so it may be a late night but I may also get to drive my car to work tomorrow. And I'll thank JW for the tips on gasket dressing and especially the Dirko case sealant. I think that stuff could seal a ship's hull. Oh, and the nose bearing is dry as a bone. (again, knock on wood)
Schleprock
Jim,
You can fire me too. I haven't helped a bit! Based on what i've seen in your threads, I think you're in good shape. Anchors aweigh!!!!
