GotaT's Avatar
Send a message via AIM to GotaT Send a message via Yahoo to GotaT
Question Altenator Pulley Tech Quest- EASY
Im wondering about the "slack" in the Alt Pulley to the Alt when installed.. Does it/ Should it have ANY play back and forth ... I know the tighter the tolerance the better. but is some acceptable? .. I have a NEW pulley and a used but in good condition alt fan.. Doesnt seem to have any wear on it.
Thanks.
Old 10-11-2007, 02:52 PM
If you are asking if there should be some slack/gap between the outer pulley half and the inner pulley half (mounted on the fan) when the fan belt is at its proper tension, the answer is an emphatic NO!
When properly installed, the outer pulley half will bolt up hard against the spacers which will be hard against the inner pulley half. And when the pulley nut comes tight, the fan belt is "just right."
If the fan belt is too loose, then disassemble it all and move one spacere from between the pulley halves to between the nut and the outer pulley half, then reassemble and check tightness.
If the fan belt is too tight, disassemble it all and move one spacer from under the nut to between the pulley halves, reassemble, and check tightness.
If the outer pulley is "loose" and can wobble, things will come apart in short order with the engine running.
Old 10-11-2007, 04:40 PM
GotaT's Avatar
Thanks for the response, but I dont think I was clear enough.... pressed for time...
When ONLY for test fitting purposes WithOut the Belt or spacers.. By just putting the Pulley on the Fan should or can there be Any play Left and Right?
I hope this is a better description
Old 10-11-2007, 07:03 PM
Super Moderator
cstreit's Avatar
The pulley (or technically the 1/2 pulley) should fit rather well to the protrusion over the fan. It's not a tolerance fit so I guess it could move a little...
...but not 100% sure that this is what you're asking
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 10-11-2007, 07:11 PM
redstrosekNic's Avatar
i know this thread is old, but this is the exact issue I am experiencing currently. I've included a video to help explain the problem. Does anyone know if this amount of play is acceptable? I hope the O.P. found the answer!
Fan video - YouTube
I'm pretty much stumped right now, as a used fan from a reputable place does the same thing my original does. The pulley half in the video is brand new.
Thank you
Dustin
Old 10-31-2011, 03:46 PM
Northern Motorhead
wildcat077's Avatar
I just removed my pulleys as my engine is out of the car and i have some play as well ... the only problem with your fan is that your parts look too clean
Cheers !
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 10-31-2011, 04:13 PM
Cheers !
Phil
Thanks for the compliment Phil! It makes me feel better knowing someone else has some play too.
Dustin
Old 10-31-2011, 08:01 PM
