ECSjr's Avatar
Question What does this switch do?
I checked the owners manual...and pushed on the switch.... but i still don't know what this does. I just found it yesterday on my '92 C2 Cab.
It is a little black switch on the side of the footwell, right behind the trunk release lever.
Thanks in advance
Ed
Old 03-24-2002, 09:34 PM
Administrator
Jack Olsen's Avatar
I'm guessing, but maybe a valet switch from an aftermarket alarm system?
Old 03-24-2002, 09:53 PM
Monkey with a mouse
kstar's Avatar
That's the 'eject' switch - don't initiate that switch while the car is moving unless you are in serious danger.
Best,
Kurt
Old 03-24-2002, 10:08 PM
ECSjr's Avatar
I don't think so Jack....factory alarm.
Old 03-24-2002, 10:09 PM
one of gods prototypes
bell's Avatar
that looks like a "clifford" alarm valet switch.
is it a momentary on one side, latches in the middle and latches on the other side? if it does that's what it is.
i'm putting my money on that
Brought to you by Carl's Jr.
Old 03-25-2002, 09:42 AM
ECSjr's Avatar
yea, it does seem to lock on the up side and you have to hold it on the down side. Maybe it locks the rear seat area storage compartments. I will have to check that out when I get home.
Thought I had the stock alarm - no record of an alarm upgrade.
Ed
92 C2 Cab
Old 03-25-2002, 11:51 AM
ECSjr's Avatar
WHO WOULD VALET THESE CARS???
Old 03-25-2002, 11:52 AM
Have you clicked the switch when the car was running? The PO of mine installed a hidden fuel pump cut-off switch and failed to infrom me. Needless to say, when the switch went out I had a very difficult time diagnosing why the car wouldn't start.
Old 03-25-2002, 12:54 PM
boyo's Avatar
I know the Boxster has a switch right about there that raises/lowers the rear spoiler. Push it! Dare ya!
-Boyo
'48 Willys CJ-2A / '55.1 Chevy 3600 / '66 Austin-Healey 3000 / '72 Porsche 911T
Old 03-25-2002, 01:09 PM
Reminds me of the Far Side cartoon where the guy's sitting on a plane, and the caption reads something like "Bob tries to get a stewardess" as he's reaching for the "Wings stay on/Wings fall off" switch.
My guess would be an alarm. Try setting off your alarm and pushing it. or pushing it and then setting off your alarm.
89 Carrera 3.4
"There is a right way to go around a corner - it's called the line." -- PCA DE speaker
bryteside.com - good things happen.
Old 03-25-2002, 01:14 PM
bell's Avatar
Ed
92 C2 Cab
i'm going to guess that your car either has/had a clifford alarm on it and the remotes were lost or not given to you when you bought it (assuming you didn't buy it new).
99.99% of the time when an aftermarket alarm is installed the factory alarm is left fully intact.
i would take a peek under the dash to see if you see anything "not stock", you can usually follow wires to find the brain of the alarm if you're nimble enough to get under there.
if there is no alarm installed the previous owner had it removed and left the switch there so not to leave an open hole (standard practice in my field).
you may get lucky and be able to buy remotes (between 20-100$ depending on the model) and have a nice aftermarket alarm
keep us posted what you come up with.
Old 03-25-2002, 01:46 PM
ECSjr's Avatar
I did try pushing it - with car off and running. I will try it with alarm armed.
I have been under the dash...didn't notice anything foreign.
If nothing happens with the alarm on - looks like i'll be taking apart that part of the car and following wires.
Ed
Old 03-25-2002, 02:44 PM
bell's Avatar
i'm going to guess it's a dead switch.
it's not going to have anything to do with your factory alarm.
get behind the carpet and see if it's even connected to anything, it's probably not.
good luck
Old 03-25-2002, 03:08 PM
Maybe it's for one of those South African security devices.
Old 03-25-2002, 03:11 PM
Every time you push that d@mn button my garage door opens....
Argo
88 Targa
Old 03-25-2002, 07:57 PM
ECSjr's Avatar
Well, no luck here. I tried the switch with the alarm on, off, ...car on, off and nothing. The switch even has a little built in light on it and is connected to wires that look very professional or factory. I followed the wires up into the back of the dash....but they went way up into an area that i can't see without removing many parts.
I think you guys are right - probably an alarm component that is no longer connected. I think I will assume its the before mentioned South African security device switch and warn everyone not to push it.
Now stupid human question #2... While I was under the dash I noticed the cover on the other footwell. I had seen it before, but never opened it up. What is this for ? Diagnostic computer connection? North African Security device?
Old 03-26-2002, 02:51 PM
ECSjr's Avatar
and opened
Ed
the momentary switch activates that device on the right..its a high voltage eletrical stunner...
it only works when sensors in the passenger seat senses an occupant...its used for when your significant other keeps telling you to slow down..
they wont even know...
you'll just hear "HONEY! slow DOWN!..ow"
'76 p-car
'98 mitsubishi eclipse
looking for a '69 912 any leads?
Old 03-26-2002, 03:48 PM
Send a message via ICQ to old_skul
Silly! That's the cyanide gas distrubution point!
Mark Szabo
1986 911 Targa 3.2 (I will miss you)
1985 Scirocco 8V (I will not miss you)
1986 Dodge B150 Ram Van (I can't believe I got $200 for you)
1987 Escort 5-speed 1.9 RIP
Old 03-26-2002, 04:17 PM
jwetering's Avatar
I'm ROFL over here.
If I didn't know better I'd suspect these pics and questions were posted just to see what kind of smart aleck responses they'd generate....
HONEY slow down...ow! Whaahahahahah!
jasper
2002 996 - arctic silver - PSS9, H&R sways,X51 oil pan, console delete, AASCO liteweight flywheel, gbox detent, RS motor mounts, 997 shifter. Great car.
past: another 2002 996 and a 1978 SC with-webers-cams-etc.
Old 03-26-2002, 04:26 PM
