hank911's Avatar
Question 3.6 cyl's on 3.0 case???
Hi guys,I posted a question a couple weeks back about 3.3 cans,same stroke as 3.0.I just came across some mahle 3.6 cyl's,same bore as 3.3,100mm.Can I used these with custom pistons without any machining?I know it's the middle of the summer but I'm thinking about winter projects and displacement increase sounds like a good one.The 3.2 upgrade is well documented but those set's seem very expensive.Anyhow thanks in advance and let me know about your cars!!!!! Thanks, Philip Hank Pallante.....
Old 07-24-2001, 03:35 AM
Bill Verburg's Avatar
Post
No, the stud spacing was moved outward from the bore center. Interestingly the bore center distances are the same for 2 - 3.8 liter.
Old 07-24-2001, 03:48 AM
