porsher
Sway bar mount
Unfortunately, a little off-track excursion bent the RH rear sway bar mount.
![]() I was already using the Wevo mount which has damaged the the sheet metal. I think the best course of action is to grind off the mount and start over. Does anyone make a replacement patch panel to reinforce the tub? I know I can make one, I was just hoping to speed up the repair.
86 911 Race Car, with a few 993 bits in the boiler room 79 928 Race Car 88 928 Becoming a Race Car |
Max Sluiter
I would use a factory mount with gussests to spread the load out. That WEVO thing looks way too strong to be welded to sheet metal. It just moves the problem upstream as you have found.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
Flieger, this is timely.
I have a pair of Wevo mounts in my box of parts. I was going to install them soon until I read your response. I have seen some mounts that weld to the torsion tube instead. What would you do If you still had factory mounts on the car?
73 RSR replica (soon for sale) SOLD - 928 5 speed with phone dials and Pasha seats SOLD - 914 wide body hot rod My 73RSR build http://forums.pelicanparts.com/porsche-911-technical-forum/893954-saving-73-crusher-again.html |
Max Sluiter
My unreinforced mount broke one day (I think it was passenger side). I had Marco at TLG Automotive weld on a new factory replacement piece (I think it was an earlier piece and not the later SC piece since mine is a '71). Then he added some sheet metal to box it in and also distribute the stress across the sheet metal. The driver side was left stock since the fuel pump mounts there.
Max Sluiter
I can't find photos.
I suppose makeing a piece that "boxes" the mount while extending the bent over lip/return that stiffens the mount so that it forms more of a trapezoid would be best. If that makes any sense.
abides.
Why not weld some nuts into the chassis and bolt on the factory mounts? That would certainly make them easy to replace each time they subsequently fail.
Graham 1984 Carrera Targa |
porsher
Something of a SWAG of course.... I'm still kicking myself for damaging them in the first place
86 911 Race Car, with a few 993 bits in the boiler room 79 928 Race Car 88 928 Becoming a Race Car Last edited by aston@ultrasw.c; 10-31-2011 at 12:18 PM.. |
Northern Motorhead
Interesting post as i was going to weld on some WEVO mounts this Winter.Guess i'll be doing some spot welds rather than a complete surround.
I would much rather the mounts tear off at the welds than my chassis being damaged ... Cheers ! Phil
Cheers Phil 89 Coupe,Black,95 3.6 engine and the list goes on ... 1983 944 SP2 race car PCA #96 |
porsher
Northern Motorhead
If you decide you are not going to use your WEVO mounts i would like to buy them from you ... my OEM mounts have been rewelded too many times ! Cheers ! Phil
Another thing to do no mater what mount or welding you do is to weld in a skid plate from the chassis over the sway bar mount. That way if you do ground out, it will not be torn off.
Something like this and also with a bar stock that would go over the sway bar mounting bracket itself.
Location: behind the redwood curtain, (humboldt county) california
My 74 rear bar mount fuel pump relocation adventure
Here is a link to my recent Wevo bar mount & pump relocation
Replacing rear bar mounts 74 911 My friend with the plasma cutter and a bunch of welding experience suggested drilling a hole in the center of the wevo bracket to spread the load. He further recommended that you not weld the entire perimeter because this could cause the body metal to tear at that point. Better to run a few tacks. I received some good advice from Grady to First put some sheet metal on the chasis to reinforce the bar mount location. I chose not to do this because i am not going to track my dad's car, well maybe once or twice. I was also concerned about building multipul layers of metal in that sensitive, highly loaded area. In particular, i was worried about sealing everything up. We did use "Weld-Through Primer". HTH, chris |
Try using the mounts from Buckley Racing. Over kill perhaps but the last mount you will need.
'87 Carrera - 2400 lbs of Track Beast!! '88 Carrera Cab - Too nice for the track. '85 Targa - Salvage title that was not caught! |
porsher
Here's an update.
So I removed the Wevos. Not suprisingly the remaining structure was not that great, so I decided to use the Buckley Racing mounts which are welded to the torsion tube and avoid the tub altogether. These mounts are very stout but I added an additional gusset to spread the load on the torsion tube and to provide additional axial strength. Here are the gussets tack welded in position. ![]() I forgot about the camera until it was all over, so here's the final. ![]() ![]() That should do the trick!!
Hmmm. Maybe a revisit to mounting the sway bar brackets onto the torsion bar tube? Lots stronger. Or a new sway bar mount location that provides minimal exposure to minimum ground clearance.
"Armoring" the factory rear SB mounts sounds similar to installing wheels/skid plates and other add-ons to the front end to avoid scraping. Sherwood |
Ya think?? Nice job. Like I said this will be the last mount you will need!
