Broken Engine Mount...F'n Previous Owners
I was installing my engine today. It took a while to get all the mounting bolts lined up. But I finally did. I start torquing the bolts and...
![]() ![]() Upon closer inspection, it appears that it had somehow broken previously, and someone decided to weld it back together. Thank god i found out this way and not while driving. So project on hold....again.
Matt. 83 911SC 85.5 944 NA - Sold |
when the bolt is removed, sometimes it's solidly rusted in the mount threads and there's no way to grab the end of the mount to prevent it from twisting.
Northern Motorhead
Matt,
I had the same issue with mine when i dropped the engine last month... It seems the mount was previously repaired by "Hank" the crosseyed welder,and it was off by almost .250 top to bottom. I had to cut it,remeasure and reweld it properly.Easy fix,just take the right measurements,tack it,remeasure and weld it properly ! Cheers ! Phil !
Cheers Phil 89 Coupe,Black,95 3.6 engine and the list goes on ... 1983 944 SP2 race car PCA #96 |
Member 911 Anonymous
Make certain you place some anti-sieze on it so to lessen the chance of it twisitng off the next time you need to service it.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
I could weld that for you, but I am up by Kingston. Let me know if you are hard up.
83 911 Production Cab #10
Matt
Don't despair... You'll get there. One of my PO transform the 12mm receiver for the transmission cross mount to a 14mm. Took me a few minutes to figure out why the bolt (now a 14) did not fit through my new transmission mount... He had drilled out his mount so that the 14mm bolt with fit through the mount into the hole that he tap at 14mm after he cross thread the original 12mm receiver ![]() ![]() ![]() Another spin-off project for the winter. Unless you got a cab, you should be able to get one relatively cheap. Check with Tom1394racing
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger Last edited by JJ 911SC; 11-13-2011 at 02:30 PM.. |
I think I'm just going to find a used one. There are a few on the board and one I found on ebay. So I should be good. Thanks.
rennline has a really nice stainless one with holes in it.
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's. 2019 Silverado 6.2L |
