tomeric914's Avatar
Simple Idle Air Control for aftermarket ECU SDS Megasquirt
Trying to think outside the box for a possible IAC valve on a 3.0 conversion to EFI using a 3.2 manifold. I know MS2 and MS3 has capability for PWM control of the stock 3 wire IAC valve, but I'm looking at either SDS or MS1.
I didn't like the options out there so far which are either a 5/16" fuel valve, a float bowl vent solenoid or an EGR solenoid valve. All were $50 or so and wouldn't exactly bolt right on.
Then it hit me, why not use a 12VDC solenoid valve like on a washing machine?
It's a normally closed valve so power is only applied when the engine is cold. The only detail I won't know until installed is what the resulting idle will be with the valve open. The hose size is either 1/2" or 5/8" so a restrictor of some sort may need to be put in line.
Old 11-18-2011, 08:33 PM
In general, I would avoid using washing machine parts on a Porsche engine. If you want something simple for cold idle, follow the factory and fit a CIS Auxiliary Air Regulator, it worked well for +100,000 Porsche engines. Many EFI conversions use them and there are plenty available used.
Paul
Old 11-19-2011, 05:37 AM
Chain fence eating turbo
I'm trying to understand how that can regulate airflow? Isn't it either open or closed?
Old 11-19-2011, 06:06 AM
tomeric914's Avatar
It wouldn't regulate airflow. MS1 or SDS is open or closed for fast warmup or to increase idle for AC engagement. This is similar to 0 280 141 012 from an early 944.
Old 11-19-2011, 06:22 AM
Ah, I see.
Old 11-19-2011, 08:28 AM
sjf911's Avatar
1+ This is what I did for a while and it worked fine, I even had the vacuum limiter plumbed in as well.
Sapere aude
1983 3.4L 911SC turbo. Sold
Old 11-19-2011, 08:37 AM
