Engine running cold, what to check?
I've recently purchased a 79 sc with carrera intake / aftermarket exhaust / tbitz efi conversion kit and in trying to get it running properly found that this car won't warm up!
Temp gauge (inside, when its +120), therm-resistor head temp sensor (from efi kit) & infrared thermometer all confirm operation temp of about 110F and a max (from recorded log) of 135
Next step I see is to check the internal and external thermostat to see if the previous owner modified these. Would an open thermostat result in this type of operation? I would still expect to see some more heat. Has anyone seen anything else that would cause this that I should check?
Thanks,
Brian
Old 11-19-2011, 10:08 AM
Solved - The front oil cooler thermostat (a Mocal H style) was stuck closed. That in combination with "boutique" oil kept the car running cold.
Old 01-21-2012, 09:38 AM
1979 911sc
Windsor4273's Avatar
My 79 has the same symptoms. How did you check the thermostat to the front cooler?
Old 01-21-2012, 12:48 PM
I'm sure this is not the most elegant way of handling this.
The front cooler was warm before it should have been. I drained the oil and took off the thermostat. I boiled some water and put the thermostat in, didn't see any movement. Then took it apart and found it seized up and ordered a new one.
There is a spring and valve visible when you look through the thermostat, no movement at heat = bad thermostat
some diagrams of the mocal thermo:
http://208.109.215.220/files/thermos$.pdf?Submit1=More+Information+and+Pricing
Old 02-26-2012, 09:15 AM
River Rat
Dave 86 930 Fl's Avatar
I use an optical temperature sensor and when the thermostat reaches 180 degrees I start monitoring the oil lines to the front cooler ... When I see the temps going up, I know the thermostat has opened. great to look at exhaust temps on the headers too. Brakes and tire temps at the track ... I could go on and on and on .
1986 930 - K27-7200, Andial Intercooler, Tial Wastegate, Electronic Boost Controller, B&B headers, Bodart Zork, Leask Adjustable WUR, Full Elephant Racing Suspension w/Adustable Spring Plates and Von Shocks, Wevo Transmission Mounts, Fuel Safe Fuel Cell, Forgelines (9"/11"), Hargett Shifter, Innovate AFR, Cobra CF Seats, DAS Rollbar, Coleman Floating Rotors, Lightweight Interior, Forgeline 17" x 9"/11", 2800 lbs.
Old 02-26-2012, 09:26 AM
