I had this high idle issue with my '83 cabriolet and, as John Walker suggested, it was my own doing. When I pulled the engine for a top-end rebuild and resealing, I went through all the CIS components for cleaning and checking.
I know I reset the throttle body stop when I disassembled and cleaned the throttle body because that 99.9 percent closure "looked" awfully tight (but there were no signs of wear).
After re-assembling everything and tuning the engine in, I found that I couldn't get my engine idle below 1,000. This had me scratching my head and looking for air leaks, etc.
Finally, I re-adjusted the throttle body plate stop (just above the point where the plate binds in the throttle bore) and this corrected things.
Brian
'82 SC Targa
'83 SC Cabriolet
Old 03-27-2012, 06:28 AM
