There is no substitute
Doing clutch.. engine will be out! Any suggestions?
Clutch needs changing on my 993 C2, engine will be out too! Its not every day you have a 993 engine out..So While its out I figured now is a good time to do any crucial upgrades, preventative maintenance... Any suggestions?
The Hacker
96 C4S
97 C2 (Gone, but not forgotten
Old 11-21-2011, 10:39 PM
RETIRED
Joe Bob's Avatar
Check for oil leaks on the of the engine under the shroud. Degrease the engine and trans.
2012 ML350 3.0 Turbo Diesel
Old 11-21-2011, 10:54 PM
Check your cv joints for wear, repack them with grease. Replace the engine sound mat if yours is worn/falling out. Check for and fix the common oil leaks.
Old 11-21-2011, 10:55 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Not sure if your Fuel Pressure Regulator is in the same spot, but I would definitely change that hard to get item. Anything that is hard to get to for that matter.
Valve adjust, Gear lube change
'85 Carrera Targa
PCA/POC
Old 11-21-2011, 11:10 PM
Valve adjust?? The 993 has self adjusting valves.
The Hacker
96 C4S
Old 11-22-2011, 02:21 AM
yel911's Avatar
How many miles? I did a complete tune-up, sparkplugs, distributor caps and rotors, distributor drive belt, new clutch and flywheel, change tranny fluid at 86K miles.
74' 911 w/3.2L (sold)
95' 993 C2 Triple Blk Cab.
02 Honda Superhawk (sold)
2018 Toyota Tundra Limited
2004 CRF250X
Old 11-22-2011, 05:06 AM
Over 100k miles...she was no garage queen.
The Hacker
96 C4S
Old 11-22-2011, 01:22 PM
ShakinJoe's Avatar
Replace that 3.6 with a 3.2 as they are much more reliable. I'll find a good home or that crappy lil 3.6!
'87 Carrera - 2400 lbs of Track Beast!!
'88 Carrera Cab - Too nice for the track.
'85 Targa - Salvage title that was not caught!
Old 11-22-2011, 02:36 PM
whatever you say joe...
The Hacker
96 C4S
Old 11-22-2011, 05:58 PM
DRACO A5OG's Avatar
Self Adjusting, that takes the fun out :P
Well, that makes it easier.
'85 Carrera Targa
PCA/POC
Old 11-22-2011, 10:32 PM
SC-targa's Avatar
Replace all the tranny seals & the engine main seals.
82 911SC Targa
(05 Boxster S ) gone, but not forgotten
87 Suzuki GSXR-1100
1953 MG TD Mk II
Old 11-23-2011, 07:50 AM
