Born to Lose, Live to Win
ramonesfreak's Avatar
Losing power while accelerating
As the weather has gotten colder I have noticed a problem with accelerating in second gear.
When accelerating with wot in second gear, I'm losing power at 3k rpm. After a few seconds it recovers. It's like it isn't getting enough fuel at that moment
Cant make it happen in other gears so far and only seems to happen when gas pedal is to the floor
Coil is about 10k miles old and plugs/wires are 15k miles old.
Any ideas why only in 2nd gear or what could be ? Thanks
Old 11-24-2011, 08:54 AM
twistoffat's Avatar
IŽd change the fuel filter and see what happens. Sounds like its clogged to me
Old 11-24-2011, 09:12 AM
I change it about 8,000 miles ago but I'll do it again
Wouldn't I get the hesitation in other gears at wot if it was a clog?
Old 11-24-2011, 09:50 AM
74 911Ebay
Check the timing, maybe the vac advance.
The world needs more Protest Singers
Old 11-24-2011, 10:21 AM
twistoffat's Avatar
I got a batch of dirty petrol once. It was most noticeable in second and third gear. Changed the filter and it seemed to fix the problem. Like many such 911 niggles its a case of solving the problem by elimination
Old 11-24-2011, 12:03 PM
muck-raker
kidrock's Avatar
a bunch of threads like this lately, a search might be your best friend. IIRC, the most recent poster found his problem at the throttle stop switch and made a simple adjustment.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 11-24-2011, 07:39 PM
