86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Throttle Body Vaccum Lines Connections.
For our '86 3.2
Does any one have pictures of the vaccum line connections on the back of the throttle body.
Best taken with the engine out of the car.
No P/N listed in the PET.
Thanks in advance,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 03-10-2011, 02:39 AM
No vacuum lines on a 3.2 TB.
Old 03-10-2011, 09:07 AM
abit off center
cgarr's Avatar
Does this help? Just stuck my phone back there, if you need a better one I can try again:
______________________
Craig
G2Performance
Old 03-10-2011, 09:53 AM
Thanks Craig.
How many vaccum ports do you have on the fitting?
Are the lines to the engine on a "T" behind the throttle assy?
Gerry
1986 911 Targa.
Only in L.A.:
Old 03-10-2011, 12:38 PM
abit off center
cgarr's Avatar
Here is a little better pic. Looks like 5 ports total. 2 that are the ambient air valve switch, one of those goes to the valve by the oil filter and one loops to the port just under the switch. One big one you can see to the left and one lower one that the Y connection goes for the fuel pressure.
Craig
G2Performance
Old 03-10-2011, 01:00 PM
Well done Craig.
Thanks,
Gerry
1986 911 Targa.
Only in L.A.:
Old 03-10-2011, 01:15 PM
steely's Avatar
Just like in the decal....
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 03-10-2011, 01:29 PM
It is tight back there.
Just two more questions.
The reason for this excercise is to run down a vaccum leak.
I was advised by one of our members to do the Propane test,
and by another, someting about a "Smoke" machine.
Since I don't have a "Smoke" machine, is there an alternative smoke source for injecting smoke into the intake?
Thanks again for your time & patience.
1986 911 Targa.
Only in L.A.:
Old 03-10-2011, 02:37 PM
abit off center
cgarr's Avatar
The loop is a vac feed for the switch, the second one from that switch goes to the amb air valve "see pic" and the Y goes out to each fuel rail at the back there is a pressure valve on the left rail and a damper valve on the right side.
Craig
G2Performance
Old 03-10-2011, 03:01 PM
steely's Avatar
Fuel Pres reg vac line
Gerry - that shot you provide from the PET doesn't look like my 87, is there a known difference I wonder?
And my lines appear to be flipped on the temp switch - matter?
Dan
Venetian Blue
Old 03-10-2011, 03:27 PM
1986 911 Targa.
Only in L.A.:
Old 03-10-2011, 03:32 PM
So, the "Y" connection goes to the base of the throttle body,
not the switch.
Thanks to you, cgarr, and steely for your time & help.
I don't like to play "fingerpoken".
Best to all,
Gerry
1986 911 Targa.
Only in L.A.:
Old 03-10-2011, 03:41 PM
steely's Avatar
to your last photo question - I confirm the "No connection..." because those lines (qty 2) were left in the car when I removed the intake. And yes, as cgarr mentioned, 2 on the temp sw, 2 TB ports (where the "Y" and loop back from temp switch attach), and the larger one there on the left referring to my pic. sorry no shot of the bare TB.
on edit : I agree: nicht mit der gerfingerpoken :-)
more edit: referring to my pic again, I replaced the loop tubing and the hunk/transition on the brake boost line where you see the shiny new clamp just to the rt if the ctr of the photo. That transition was shot on that pipe.
Dan
Venetian Blue
Old 03-10-2011, 05:12 PM
Easily Confused
dtxscott's Avatar
That is a creative way to save $100 on that pipe!
Scott C.
'08 Cayenne GTS 6MT : '89 Targa GP White/Black - "Oliver's Car" : '11 Mitsu Evo X : '08 Lexus IS350 F-Sport : '01 Toyota Sequoia : 1998 Yamaha V-max : 1979 BMW R65
Old 03-11-2011, 11:35 AM
Vaccum lines
Thanks to all for your help.
Gerry
1986 911 Targa.
Only in L.A.:
Old 03-11-2011, 02:35 PM
I needed this information as well, thanks everyone.
Its easier asking dumb questions than fixing dumb mistakes
1974 Porsche 911 Coupe, RSR Project
1976 Porsche 911 Targa, Black
1986 Porsche 911 Carrera, Black
2006 Porsche Cayenne S, Black
Old 03-11-2011, 07:43 PM
MConn's Avatar
I am chasing vacuum problems on a 1987 3.2 Carrera - stock.
What should a Motronic vacuum read at idle ??
When the thermo switch heats up, will the ambient air vale make that vacuum value go up ??
Old 11-24-2011, 08:22 AM
