3.6 conversion electric help
Hello All,
Looking for some help in helping me figure out which colored wires go to the "Hall Sensor" on the distributor. My harness has what looks to be a 3-pin plug that is cut with a second 2-pin plug next to it. The 2-pin plug is the one i believe goes to the belt sensor on the fan and the other on my hand is what i believe is for the hall sensor that the 3-pin plug has been removed from.
So....
a) Confirm these are actually the wires that go to the 3-pin plug for my hall sensor
b) If this cut 3-wire i hold is for the 3pin plug which is 1, 2 and 3? and in which order. The only alternative i have investigate the hall sensor on the distributor by dissassembling it.
c) Does someone sell the connectors that slips into the distributor hall sensor 3-pin plug?
thanks in advance
Here is the engine installed (Note the hall sensor covered in blue tape)
3-wires with plug cut off (1 White ; 1 brown ; 1 bare with red fabric at bottom)
One more
~Al
1974 911 3.0
1971 911T 2.2
Truck & Motorcycle
Old 11-21-2011, 11:20 AM
356graham's Avatar
a) Yes. Looks like them - white, brown and a shield (bare).
b) From the workshop manual;
1-white (+5 V to hall sensor, pin 12 on DME)
2-brown (hall sensor, pin 8 on DME)
3-shield
c) Don't know. Sorry.
FWIW, my understanding from other discussion on this board (search hall sensor), the engine will start and run without this connection, but not optimally.
Good luck!
Jeff Graham
'56 Speedster
'72 911E Targa
Old 11-21-2011, 01:07 PM
Thanks!
a) Great
b) Exactly what I was looking for
c) My search continues...
Ah confirmation to the not so optimal situation when running hall sensor unsuccessfully. I guess in the situation my harness is in, it would be to test the connections from engine to dme connector.
~Al
1974 911 3.0
1971 911T 2.2
Truck & Motorcycle
Old 11-21-2011, 01:27 PM
Grand Am/IMSA Data Guy
Porsche84's Avatar
dist wires
Al
I have run my 3.6 without the 3 pin connector plugged in, in the shop but not on the track. I found this drawing of the ecu connector, which might help. I have a bunch of other conversion wiring diagrams if you need more info. Do you need the plug for the Dist? I have a spare harness but I think I sent that connector to someone a while ago. I can check if you need it.
Jerry Austin
AIM Data Products Dealer
84 911 3.6 track car - Sold
Morris Minor Van with S2000 running gear
http://austinmotorsportsllc.com/
Old 11-21-2011, 04:13 PM
rsscotty's Avatar
If you need the connector for the distributor check with Geoffrey Ring at the link below.
He does Motec conversions, so this would be a basic for his wiring supplies. Make sure you have the proper crimping tool for putting on the new connectors. He can advise you on this if you don't have the tool.
EFI and Data Aquisition Specialist - Above the Standards
Old 11-21-2011, 05:39 PM
Thanks everyone for the schematic and lead on the plug. Hopefully I'll get the engine to start sometime this week. Got the exhaust, oil lines, throttle linkage connected.
~Al
1974 911 3.0
1971 911T 2.2
Truck & Motorcycle
Old 11-21-2011, 11:07 PM
Bill Verburg's Avatar
Originally Posted by Porsche84 View Post
Al
Jerry, that's for a 964
here's the '95, US, non-vram,993 connector
Bill Verburg
Old 11-22-2011, 07:05 AM
3-shield
Good luck!
According to the " '89 Carrera Service Information Technik" (WKD 495 121) manual I have, the DME unit reverts to unit stored values when a required signal is not "plausible". For the Hall Sensor, when the signal is not plausible or missing, the replacement value is as follows: "Beginning with a certain engine load, ignition timing retarded 6deg for all cylinders and knock regulation switched off"
So obviously the Hall sensor purpose is to facilitate ingnition retard when knocking occurs.
By the way, the aforementioned manual is a treasure trove of info on the 3.6 964 motor and systems. If you ever see one available, snap it up!
'80SC Widebody 3.6 transplant Anthracite "The Rocket"
Long gone but still miss them all:
'77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!)
'71 911T Coupe White, '70 911T Coupe Blue
'68 911 Coupe Orange, '68 911L Soft Window Targa
Old 11-23-2011, 02:09 PM
