Cr220 how to install into SC
Have a Becker cr220 lying around that I thought I'd put in my SC any one have instructions on how to accomplish?
Jeremy C.
Why's he calling me meat? I'm the one driving a Porsche. (Bull Durham)
----Nothing is far away in this car!---
-2001 996 Turbo
Old 11-26-2011, 05:27 PM
Fleabit peanut monkey
Bob Kontak's Avatar
What parts do you have with it? There is a security cage that wraps around the unit at least in my CDR 210.
Old 11-26-2011, 06:49 PM
Just the head unit
Old 11-26-2011, 08:40 PM
Bob Kontak's Avatar
CDR-220 Head Unit - Boxster Tech
I would call Becker.
Old 11-26-2011, 08:45 PM
I bought one on ebay last year and had a shop fit it. The only minor problem was that the unit was slightly larger than the frame fitted in the car at the time. They got over that and the wiring connectors in about one hour. Message is, take it to a pro
Regards
Ian
Old 11-27-2011, 08:53 AM
Thanks for the info. Anyone else?
Jeremy C.
-2001 996 Turbo
Old 11-27-2011, 09:41 AM
Bob Kontak's Avatar
Have you searched on the internet for installation advice?
Old 11-27-2011, 10:12 AM
Not yet, but since it is a porsche radio thought someone has done it.
Jeremy C.
-2001 996 Turbo
Old 11-27-2011, 10:20 AM
CabMike's Avatar
I installed one in my 1983 SC last fall. I used a harness I purchased from BeckerAutosound.com. I have a pdf of the manual I found on the web and it has all of the pin outs. You will have to send the display in to have it changed so that it is viewable once installed (The SC is a vertical front while the boxer / 996 is at an angle). The radio fit with no problems but I was replacing an aftermarket Alpine.
PM me your e-mail and I will send you a copy of the manual if you don't have it.
Mike
1983 911 Cabriolet (3.6L conversion)
Guards Red
2007 BMW X5
Old 11-27-2011, 10:27 AM
Bob Kontak's Avatar
I remember it being very easy. It boils down to the security / theft cage (which I disposed of) and a couple of connecters. Without the connectors you are dead. You will also need to figure out the security code. Becker can probably help with that, too.
- Instructions
- Connectors (including MP3 connectors)
- Screen fix
- Security code
FWIW - I love the 210. Fits and looks good in an 81, even though far from period correct.
Old 11-27-2011, 11:00 AM
Yeah didn't think it would be too tough. I will get the harness from Becker. There is a guy on rennlist that does the face plate mod so if he contacts me back i may just send it to him.
Did any of you guys rout new speaker wires? To me the rears see like they are running off one channel. I think a later style Blau (charleston) was added to my car.
Jeremy C.
-2001 996 Turbo
Old 11-27-2011, 11:20 AM
4flyboy's Avatar
Hey I used this guy........
I used the guy thats mods the face. His name escapes me but he was a stand up guy and answered my inane questions with patience........the problem with the face is that it mounts at a different angle in the original car and is difficult to read from the pilots seat in our unit unless tweaked. This guy will tweak it for you......reasonable and knowledgeable. Scott
Scott
"Houston, Tranquility Base here, the Eagle has landed"
Silver 1984 M491 Sunroof Coupe
Old 11-27-2011, 12:47 PM
Thanks Scott. I hope Jim will retun my email.
Jeremy C.
-2001 996 Turbo
Old 11-27-2011, 01:06 PM
Bob Kontak's Avatar
I ran new wires. Beefed them up a little in size. My rears had been replaced before and they were wired for stereo. That is left/right and fader.
Old 11-27-2011, 01:45 PM
Yeah I am not sure what was done before but something just done sound right.
Jeremy C.
-2001 996 Turbo
Old 11-27-2011, 03:25 PM
Just wanted to give you guys an update, I sent the faceplate to Jim and he performed the mod right away.
I should be getting the harnesses from Becker in about a week and will begin with the install.
If I dont freeze in my garage.....
Jeremy C.
-2001 996 Turbo
Old 12-08-2011, 10:21 AM
I received the wire harnesses from Becker but looks like hey send the wrong antenna adapter.
Does anyone have a wiring diagram to which wires the spliced or connected to?
Jeremy C.
-2001 996 Turbo
Old 12-17-2011, 11:59 AM
Shhhh... Uhhh
Creve's Avatar
Can you tell me or PM me how to contact the guy who did your face plate? Need to do mine. He sounds like the perfect answer.
TIA
"Dyin' ain't much of a livin' boy."
- Outlaw Josey Wales
Old 12-26-2011, 09:44 PM
PM Sent
Jeremy C.
-2001 996 Turbo
Old 12-27-2011, 08:04 AM
