Lug Nut Socket Size?
What size is the socket / wrench size for the standard Fuchs wheel? I can't find a replacement wrench for sale anyone on this site and was curious.
Can someone please tell me the socket size?
1979 911sc owner in San Diego. My first post and story on the Pelican Forum can be read here - http://goo.gl/7WZjp My favorite website can be viewed here - http://goo.gl/MPWUA Thank you, this is a great forum! ![]() |
19mm.
3/4 will also work.
Tru6 Restoration & Design |
Thank you, I know it's a dumb question but I have limited access to a Garage as I live in a high rise and most of my tools are in storage.
better a "dumb" question than rounded out and ruined lug nuts.
On topic-ish: My original 19mm black lugnuts are pretty scuffed. Once I replace (assuming replace is best practice vs. re-paint/re-anodize), should I:
- get one of those special "non-marking" lugnut sockets - or just be careful Thanks!
1985 Coupe, 2007 Cayman |
Just be careful. You can polish them but they might look odd with black center wheels. My soft socket broke apart. Use a good quality 19 mm deep socket with a breaker bar and you should be fine. Most importantly, make sure you Torque the wheels to 96 ft lbs. Do not over tighten those aluminum jobbies.
'87 Carrera - 2400 lbs of Track Beast!! '88 Carrera Cab - Too nice for the track. '85 Targa - Salvage title that was not caught! |
Bird. It's the word...
There are also sockets that grip the "sides" rather than the "corners" of the lug nuts... sort of a 'star' shape when you look down the barrel; these cause less damage/buring/scuffing to anodized lug nuts.
John Forcier Current: 68L 2.0 Hotrod - build underway |
You have a lady friend who uses panty hose? No, not being kinky here...try placing panty hose material between the socket and the wheel nut...my tip of the year.
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
Non Compos Mentis
I've touched up scuffed lug nuts with a black Sharpie pen. Unless you're going to have a Concours judge looking at them with a magnifying glass, they look fine.
Non Compos Mentis
With tools in storage, just these wrenches:
10mm, 13mm, 19mm, you will be able to twist about 80% of the bolts & nuts used on a 911. |
adding 15 and 17 gets you to 95%.
Flat Six
+1 and a 19mm lug wrench should be in your frunk anyway . . .
Dale 1985 Carrera 3.2 -- SOLD 2026 Jaguar F-Pace / 2025 Ford Bronco Sport |
Thank you for the tip!
