Flares & wheels for 72 911 with a 3.6
I have a 72 911t with a 993 engine in it. The rear fenders are rolled and we modified 8x15 fuchs to fit. The tires are Hoosier R6s-225/45/15. This is not enough rubber for track events. I am planning to install SC metal flares and a fiberglass RS rear bumper. I don't want to have turbo or RSR flares. I was thinking about 16x9 fuchs, but what size tire? Will a 275/45/16 fit? Should I consider a 3 piece wheel 17 or 18 inch? 9 or 10 inch wide?
Thanks for any input. |
RETIRED
SC flares will allow for a 245 on an 8 or 9 inch wheel.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
W/ SC/Carrera flares you can use a 9.5" wheels, 10" if you really finesse everything a 275 or 285 tire will fit but everything has to be perfect. Look at the tires you want to use for track days. That will determine what wheels to use. if you use HoHos then you are golden, get 9.5x15 ET19 wheels and use 275/35 x15 275/45 x16 are ~ 2.5" taller than the Hoosier 275/35 x15 and commensurately harder to fit, they are also commensurately worse wrt gearing, 275/40 x17 are slightly shorter than 275/45 x16, in 18 you can use 280/30 x18 which is only 1.9" taller than the 275/35 x15
RETIRED
While I will defer to Bill on his advise....everything has to be perfect and you will have an RCH in clearance.
Big tires are harder to find nowadays for 15 and 16 inch wheels.
Non Compos Mentis
The advantage of installing flares on a long hood is that you can put the flares where you want them.
When the Carrera flares were installed on my old '73 hotrod, we borrowed a set of 10" Fikses with 275 tires. The flares ended up being cheated out about 3/8 further than what the factory used to leave a bit of wiggle room for 275s. To do it again, I would do the same. |
Administrator
This is a Fuchs center welded into a 10x17 barrel. I used to run 275's on it on the RS-flared version of my car. You have to massage things just so -- including machining one of the heads of the spring plate bolts, if I remember.
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
Jack and others are leading you in the right direction. I had to machine a spacer 1/8" different from side to side and massage the Carrera flares on my 72'. Not surprisingly, as many here, Jack's first 72' was the inspiration for my 72' build. I ran 265's on my 10's with no issues quite a bit below Euro. Now running Alton's 17's with his standard spacing with even more clearance. I did have to shave bolts as described too, but no tub modifications.
Luke S. 72 RS spirit 2.7mfi, 73 3.2 Hotrod on steelies, 76 993 3.3efi TT, 86 trackrat, 91 C4s widebody,02 OLA winning 6GT2, 07 997TT, 72 914 v8,03 900 rwhp 996TT |
72 911 flares/wheels
Thanks, Richard |
If you want to use 18s, again decide on what brand of tire you want to use first For track use 285/30x18 Hoosier R6, Michelin Sport Cup, BFG R1, Kumho 710 etc come to mind, all are ~24.9" tall For 18" I've found Forgeline to be able to supply custom o/s wheels, I was able to spec the exact o/s that I needed for my track wheels from them. Also consider what you will use in front 8" wheels are going to be the max w/ 235 or 245 tires to match the rears in height and width ratio As Dantilla says the nice thing about adding flares is that you can cheat them out, Ruff cheated theirs out an extra inch to accommodate a 10" wheel. It's best to have the wheel mounted on the axle then fit the flare around it. Width and ET are the specs that determine fit, height to a lesser extent
RETIRED
That 915 with BIG modern rubber is gonna take a beating. I would suggest looking at people that have done WEVO mods.
