removing rear axles...??
I'm guessing I just need to put an allen wrench on the CV joint bolts??
They aren't budging and I've used a hammer against the allen wrench... but I don't want to strip it down trying to get these off.
Anyone have some suggestions?? I'm guessing it is still counter clockwise to take them off??
Should I hit each bolt with some PB blaster??
What's the trick to get these axles off the transmission?
(This is a the last step I need to do before dropping my engine and trans)
1987 Porsche 911 Carrera Coupe
Old 10-01-2017, 01:34 PM
They're simple socket head cap screws, should be straightforward removal. I strip a bolt head every once in a while, but usually can get them out with a pair of vice grips on the outside as a last resort.
Matt - 84 Carrera
Old 10-01-2017, 01:43 PM
Fleabit peanut monkey
Bob Kontak's Avatar
Get quality vice-grips. Real ones. Standard nose, not long ones. Bust them loose and then replace on re-fit.
There is not a lot of torque on them, in theory.
1981 911SC Targa
Well.. following the Bentley manual... its the last step, but the axle turns when I try to move it.
Perhaps a PO used an impact wrench to put them on?
I've put an allen wrench on one of the bolts and used a hammer as hard as I could and still it won't budge.
I blasted them with some PB Blaster as I'm lost as to what to do now.
I guess I will keep trying each week... but was hoping to have it finished today.
Old 10-01-2017, 01:58 PM
Do you have a 6mm hex that you can use a ratchet on? Works like 10x better than a L-shaped allen wrench. (I think it's 6mm...)
Oh and set the e-brake to stop the wheels from spinning.
Matt - 84 Carrera
Old 10-01-2017, 02:04 PM
Carrera 3.2 CV bolts removal........
Recently replaced the torn CV boots of an '87 Carrera and I used an impact wrench to loosen the bolts. If you need to remove the half shafts for some service or maintenance, don't forget to loosen axle bolts. Replace old and worn out CV bolts.
Tony
Old 10-01-2017, 02:15 PM
Clean out the cap heads on those bolts real good. It will help you find good purchase and help avoid stripping. Use the ratchet.
Old 10-01-2017, 02:40 PM
Formerly known as Syzygy
Canada Kev's Avatar
First thing: be sure to loosen your axle bolt before raising the car to do the CV joint side. Park it in gear, use your parking brake, chock your wheels and get yourself a big breaker bar. That nut is torqued to 340ish lbs-ft on your car.
Use the socket Allen wrench like Matt suggested. You can put a lot more leverage on those as required.
As Tony said, get a pick or something to make sure that any crud inside the Allen head of the fastener is gone. It's gotta be super clean to ensure your Allen tool sits nice and tight against the bottom. With that thought in mind, it probably wouldn't hurt to tap your Allen socket in a bit with a hammer before turning to make sure the tool is seated firmly in the bolt.
Your axle shouldn't turn if it's in gear and your e-brake is on.
Kevin
Old 10-01-2017, 03:56 PM
Brew Master
cabmandone's Avatar
Get a good set of allen head sockets. They'll be your best friend when it comes to removing the axle shaft bolts.
Old 10-01-2017, 04:10 PM
More Likeable IRL
juanbenae's Avatar
bonus hint... put a screw driver in the rotor vents to secure your tightening or loosening effort. pinched the fuch out of a pinky finger learning this. beware.
Old 10-01-2017, 04:19 PM
Thanks... I'm not sure what you're talking about?? What nut is 340lb torqued?
I have about 8 or so bolts along the outside of the boot cover that attaches to the transmission.
I need to take the axles off the trans so that I can remove the transmission and engine.
Those allen head bolts are giving me a hard time... I've put an allen wrench in them and tried to turn them counter-clockwise using a heavy hammer to get them to break loose and they aren't budging.
According to the books I'm looking at... they should only be torqued to 40-60lb. or so... These bolts are too small to be torqued over 100lb.
e-brake is on... not sure about the gear, as I've already had the shift coupler removed to prepare to drop trans.
Old 10-02-2017, 05:50 AM
Thanks... I'll have to pick up that tool and see if that helps.
e-brake is on... but obviously putting enough muscle into it still turns it slowly.
Old 10-02-2017, 05:54 AM
Spiderman
Jesse16's Avatar
They're just tight, probably been awhile since off. You gotta stop the axle/wheel from turning any way you can and apply torque safely. Maybe a great excuse to buy an impact wrench of some type. I went the harbor tool route since they're low cost and I already have a little compressed air. For as little as I need that tool, has worked great. Or just get that adapter above and a 3/8" breaker bar, I love mine.
I always look for someway to jam the tire from rotating, be creative.
Midnight Blue 08 Cayman S, Fun/Track
Black 12 VW-GTI, work
Mexico Blue 87 Carrera, sold, sad, not enough garage space.
Old 10-02-2017, 06:31 AM
tobluforu's Avatar
He's talking about the nut that holds the hub, etc in place. That is a beaaatch to break loose.
One of the best tools in my garage in the impact wrench. Man do I love that wrench when the lugs nuts are frozen after a wonderful winter filled with snow, ice and salt. Comes in handy for other jobs as well. Might need to add a piece of pipe to get some leverage. I have been known to break loose a few nuts and bolts using a swift kick
Old 10-02-2017, 06:51 AM
Brew Master
cabmandone's Avatar
Not sure why people are suggesting breaking the hub nut loose? The axle shaft should drop down once you take the allen bolts off the back side of the hub and off of the transmission flange.
If you're buying an allen head socket, get a hardened impact style. I rounded one when trying to loosen one of mine. I also found it helpful to put a block of wood under the tire to help secure it while breaking the bolts loose. A bit of penetrating oil wouldn't hurt as well.
Old 10-02-2017, 07:06 AM
Spiderman
Jesse16's Avatar
Now if you plan to fully remove the axle assembly from the car you will need to remove the big nut from the axle end out at the wheel. At the tranny end its just the 6 or 8 hex end bolts. Tons of discussion on how to remove that nut safely, I've never had one fight me harder than my 1/2 beaker and 24" cheater pipe couldn't handle. Again, an impact wrench (mine is air) works super well on this specific task.
Old 10-02-2017, 07:19 AM
Charles Freeborn's Avatar
I use a 3/8" drive pneumatic impact with the aforementioned hex "socket". A battery powered will work too.
Bone stock 1974 911S Targa.
1972 914/4 Race Car
Old 10-02-2017, 07:29 AM
Brew Master
cabmandone's Avatar
On other thing to note, if you can buy the longer version of that allen socket, get it and if you have an air impact along with an impact swivel you can lightly "bounce" the bolts with the impact. You just want to be careful you don't break one off in the axle or transmission flange.
What I did with mine when removing was rotate the wheel so I had easier access than trying to work my way around the axle.
Old 10-02-2017, 07:31 AM
Counterclockwise?
Maybe clean and PB the exposed end of the bolts and take a wire brush to it.
With the wheel off I found if I used multiple extensions the impact gets absorbed and nothing happens. Using a long pipe did the trick on my 86.
Clean out the holes and tap the allen in nice and snug.
Rod
1986 Carrera
2001 996TT
Old 10-02-2017, 10:54 AM
porsher
aston@ultrasw.c's Avatar
Don't hammer. Use additional leverage as others have said.
Check that you have 6 point allen bolts, many cars came with a 12 point.
Please take your time!!
If you think this is bad try removing the bolts after you strip the head.
86 911 Race Car, with a few 993 bits in the boiler room
79 928 Race Car
88 928 Becoming a Race Car
Old 10-02-2017, 11:46 AM
