Deadeye's Avatar
Originally Posted by Bill Verburg View Post
That's a potential issue when you use a caliper adapter, anything that reduces the stiffness of the components or increases the lever arm will exacerbate that sort of thing, for stock setups it's not an issue
Bill, that makes sense as the caliper adapters do introduce additional material between the caliper and trailing arm/strut. Time to start searching for a 930 set up. The PO of this car installed the boxster set up because he was cooking the seals in the stock calipers and the boxster calipers cured this in a cost effective way.
Steve, I didn't think floating rotors in that size were available, but if they were, someone on this board would know.
Old 12-08-2011, 02:58 AM
