Shuz
New Rattle on 911 sc
My new old 911 has developed a rattling noise that sounds like its comming from my gearbox. The sound is most noticeable while idling in neutral foot off the clutch
Sound disappears when I put the clutch in. Any thoughts?
The car runs and shifts fine without grinding or hesitation.
I do notice on occasion, that if I need to maneuver in a parking lot, drive forward or back. The car sounds like something is not completely disengaged. ( ex. Accelarate in gear, then clutch down and coast while still in gear)
I don't know if the two issues are related, but I am sure someone reading this knows what I am talking bout.
Any info would help
RBL
Old 12-05-2011, 09:52 PM
SCOTITUDE's Avatar
Send a message via AIM to SCOTITUDE
throw out bearing
1980 911SC #99 track car, 993 3.6, 50 PMO's
2019 Ford F150 da dragger
2015 MB SL400 wifey DD
2008 E93 M3 DD
2007 E60 530 wifey winter beater
Old 12-05-2011, 11:08 PM
Shuz
Can we speak dollars? Is it something I live with until a major job... Or is what you saying I am gong to need major service very soon?
Old 12-05-2011, 11:21 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Part itself is cheap $160-$190 depending on your year, but you also would want to swap the Guide tube and Guide tube Seal $100. But requires and engine/trans drop
The 915 Trans has the clutch chatter/ratlle so that is normal.It is most apparent when windows are up, The T/O bearing actually runs against the pressure plate which is where the noise is coming from. A new one will help but over time it will start to rattle.
No need to change it right away. Just make sure on the next Clutch Job the wrench replaces the T/O Bearing, Guide tube with seal and New Fork. Will not hurt to replace the pilot bearing as well.
Post an audio clip and we can tell better.
'85 Carrera Targa
PCA/POC
Old 12-05-2011, 11:46 PM
Hey, that sounds familiar.....
I got a noise...
Old 12-09-2011, 04:01 AM
RETIRED
Joe Bob's Avatar
Sure sounds like a TO.
2012 ML350 3.0 Turbo Diesel
Old 12-09-2011, 09:30 AM
