Loose green wire behind gauges
Hi All,
Behind my gauges I see a solid green wire with a female spade connector not connected to anything. Per the Bentley gauge wiring diagrams the only solid green wire goes to the fuel level gauge and that's present and working properly. As far as I can tell everything's working properly. Any idea where this wire belongs? |
RETIRED
Anything NOT working?
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
I have that same mystery wire. Mine is tucked up under the radio. I have not figured it either .
Member 911 Anonymous
Post a pic, if all is functioning, do not worry about it
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
I had a random green wire under my frunk near the passenger head lamp. I tested it and my horn went off, but the horns works fine o.o . Maybe some sort of alarm add on that was never picked?
Wash. State
Frunk? You have a frunk? Wow....I'd get that checked.....
Ha, yes, everything's working properly. I'll take the gauge out and take a pic. It comes out about 3-4" from a sheath with other gauge wiring so it can't really connect anywhere other than the gauge area.
1980 911SC |
Registered speed offender
I found the same green wire on my 78 the other day when I was hooking up my gauges and spent an hour looking through the dang wire diagrams trying to figure out where the heck it was supposed to go??? I found a couple threads here with some asking the same question... nobody seems to have the answer.
If you keep looking back, you'll never move forward. http://forums.pelicanparts.com/paint-bodywork-discussion-forum/506621-project-911r-something.html |
The green wire to nowhere is on my 1973 diagram. It was for the Sportmatic trans.
Ed 1973.5 T |
