stubbern axle bolt removal
Hello all; while starting my engine drop, I have run into my first obstacle. Removing axles from trans. It seems the #8 Allan head bolts don't want to budge. The Allen head socket do not fit tightly in the head of the bolts, and I can see that they are at the point, that if I use any more press on them, they will strip. I've already given them a good hit with a hammer, but no go. Any pointers/tips. thanks Philip
87 930 GHL/Rarlyl8/Garretson/GT3582R/1 Bar/Wevo shift, mounts/Meth inj/LM-2/Custom Fuchs/Carrera intake manifold/Xtreme Carrera heads P&P/3.4/DR 993SS cams/ Mahl/Pauter/JE/Niresist/ARP/twin COP/8.25:1/KEP stage 2/twin tials/close 2,3,4th. MS3Pro Evo 500+ HP, BTSOMP Dyno
Old 12-17-2011, 05:29 PM
Send a message via Skype™ to Porboynz
Good quality allen bits that fit, I have a set of 1/2 inch drive allen sockets that I use rather then the L shaped ball head keys. Make sure the heads are completely cleaned out and the key is firmly seated. You can also try using your biggest set of mole grips at the same time. If the bolt allen head is trashed you can get really innovative with an angle grinder, I have a grinder with a cutoff blade that I have used to carve new flats on stuck bolt heads. Sometimes you can drive an imperial measure allen key into a metric bolt head. Next step is to cut the heads right off with the grinder, you will be replacing them anyway right?
1972 911T Coupe with a '73E MFI engine and 'S' pistons
10 year resto mostly completed, in original Albert Blue.
***If only I didn't know now what I didn't know then***
Old 12-17-2011, 05:39 PM
Air chisel the edge and get a notch and the chisel should start it out. Sometimes you can drive in a 12 point in and get a good hold too.
Bruce
Old 12-17-2011, 05:44 PM
Oh, one more thing, apply maximum force (as much as you think you can apply before stripping it) then get a mate to smack the end of the socket bar with a ball hammer. The sudden shock sometimes gets them loose. Don't use your best socket set T bar for this. Pre heating the housing with a propane torch can also help but can cause collateral damage to seals etc.
I think someone in the past must have reused the bolts over. I have a set of good quality Allan head sockets, the bolts are nice and clean, but the 8 mm still wobbles when inserted in the head. I guess i will have to try pound a larger size in. I'd like to try get them out before cutting them off. I don't have a air chisel, as I'm in my home garage, and all my tools are electric. Maybe its time to invest in air tools. Philip
Old 12-17-2011, 06:05 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Be ready to replace the questionable one. When I dropped my engine/trans, I had 6 new on standby, had to use 1 new one due to a stripped head.
+1 use a chisel to break it loose and discard.
'85 Carrera Targa
PCA/POC
Old 12-17-2011, 07:02 PM
schumicat's Avatar
spray some PB blaster on them and let soak overnight.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 12-17-2011, 09:44 PM
ROW '78 911 Targa
timmy2's Avatar
If you have an impact screw driver handy install the hex socket (On the tool) and hit it with a 2 lb hammer. Only do this to the top one then rotate the next one to the top, that gives you the clearance to do it.
I'm talking about one of these:
SNAPON TOOL 3/8 DRIVE IMPACT SCREWDRIVER SOCKET DRIVER PIT120 5.5" | eBay
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 12-17-2011, 10:32 PM
I think I read once of someone putting valve grinding paste on the allen tool to take up some of the slack in a ruined allen head bolt, might work. Driving in a Torx tool might also give you another shot at it.
Old 12-17-2011, 11:33 PM
Mo money = mo parts
+1. I would also put vice grips on the bolt head, so using the allen attached to a rachet and the vice grips after you soaked with PB or similar. You just need to crack it.
Also, order new bolts for the reinstall.
Greg
86 Coupe (stock - pretty much like Butzi designed it) - gone, but not forgotten
65 Ducati Monza 250 & 66 Monza Junior (project)
"if you are lucky enough to own a Porsche, you are lucky enough"
Old 12-18-2011, 06:09 AM
Home of the Whopper
Some (most?) of the time you have to clean out the head so the allen head socket fits snug. Lots of crap gets collected in there. I use a dental pick, then tap the socket a little to get it to seat better.
Also, maybe your allen head is a little rounded. Might have to grind the end down a little bit.
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller
Old 12-18-2011, 09:33 AM
PB blaster
OK guys, I got them. I drowned the hub assembly in PB, waited a couple hrs, good hit with the hammer and voila! But I think replacement of the bolts is a must. My Allan socket is almost new, no wear, and very loose in the bolts. thanks for all the reply. Philip
Old 12-18-2011, 09:50 AM
gearhead
For CV axles this is the law in my house. I don't care how easy they came out, how unmarred they are. I use new CV axle bolts every time I work on a CV.
And given that, I've been known to break loose stuborn ones with a pair of vice grips on the outside ribbing of the bolts.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 12-18-2011, 10:26 AM
DRACO A5OG's Avatar
Remember after 500 miles+/- re-torque them just to make sure. I am sure it will be okay but better safe then sorry.
Take care on the gasket, if you have them, they are very easy to rip.
'85 Carrera Targa
PCA/POC
Old 12-18-2011, 11:09 AM
Banned
Why?
Old 12-18-2011, 11:43 AM
DRACO A5OG's Avatar
^^^ +1, last 3 well known wrenches here did not replace them just the ones that had questionable/rounded bolts. Heck, plus they never called me back to re-torque but I see the good reason to re-torque, kinda makes sense, just incase I missed one or two being an amateur.
'85 Carrera Targa
PCA/POC
Old 12-18-2011, 11:53 AM
Nice work Philip, all these suggestions probably scared the bolts loose.
Old 12-18-2011, 10:55 PM
ROW '78 911 Targa
timmy2's Avatar
I think he used the principle in my sig.....
Dennis
Old 12-18-2011, 11:01 PM
Racer
winders's Avatar
Originally Posted by Ronnie's.930 View Post
Why?
Probably because Porsche states you should use new bolts. In theory, the bolts are designed to be stretched once and do not return to their original length when removed.
It's one of those "penny wise, pound foolish" deals. If you don't spend a little bit now to get new bolts, you may be spending a lot later to fix the damage from failed bolts.
Scott
Old 12-18-2011, 11:11 PM
Im fairly certain my seized axle bolts are either going to strip or break when I try to remove them. What at my options here? Given their location, looks tough to drill out. Should I PB blast and go for it? Worst case, how do you get these out if disaster strikes?
Old 12-19-2011, 01:26 AM
